DVBSky-S950 (PCIE)" and the "STAB HH-100", problem...
Hello everyone this is the first time that I am writing, I need a help.
I have a "DVBSky-S950 (PCIE)" and the "STAB HH-100"
I can not move dish the with "BVBViewer 5.3".
The "STAB HH-100" is configured with "DiSEqC 1.2".
The engine works if I connect it to AZBox.
Between the PC and STAB, there are 25mt.
I have Win7 64 on "ASUS H87m-plus" with 8GB Ram, a simple PC.
Where I'm wrong or "DVBSky-S950 (PCIE)" and the "STAB HH-100"
with "BVBViewer 5.3" do not communicate well?
Thank you for any replies.
Hoping to solve my problem, Thanks again.
Bye, Bruno.
Try the DiSEqC Editor of Transedit. If it doesn't work it's probably not implemented for you card.
I tested the power output of S950, these values :
- no load (S950->1mt Sat cable witout a motor) 13,5 or 19,5
- with load (S950->25mt->motor) 5volts Always
The extra supply power adapter is connected to S950.
For me 25mt. is too much for the S950,
I think I'll have to buy the interface "MS220" from Stab.
  • 1 month later...
Hello problem solved!
I purchased the "MS220" of the "STAB".
The "S950" NOT able to move the dish if there is 25mt. between card and satellite dish.
Bye, Bruno.
