What is the best codec or filter free or paid for DVBViewer Pro
MGadAllah
Under Direct X settings in DVBViewer Option there is a lot of choices for video and audio codec.
I am confused about which codecs to use to get the best result quality.
I do not mind free or paid as long as it is the best one.
Thanks a lot,
Mohamed
...as long as it is the best one...
There is not a "predefined" best one, the best settings for a specific PC are depending on too many variables (HW, O.S., driver and so on...) and the best and fastest judge are your eyes... Anyhow there are many infos about that topic in the Options DirectX wiki page...
But if you are in a hurry my suggestion on A&V codecs - if the PC is XP based - is LAV Filters suite, freeware and suitable for almost all A&V type of stream; if the PC is 7 or 8 based you can find other suggestion here in the forum (eg Microsoft and Cyberlink), but probably LAV Filters are working just fine also on 7 & 8 O.S..
:bye:
LAV Filters get my vote
Same here. Works like charm
I am using windows 8.1 pro with media center.
  • 1 month later...
my system with win8 x64 works good with lav filters
