Win 8.1 with Update doesn't let TransEdit to work normally
There is a small discomfort under Windows 8.1 with Update. When you use TransEdit to scan new channels and get the new Channels.ini file the Windows doesn't let to write it into the default catalog despite of you are working as Administrator. It proposes to write the file in \Windows\users\user_name\Documents. So you should copy it to DVBViewer catalog or take/import it from Documents.
Run TransEdit in the DVBViewer folder. And it will use the configuration folder
So I did, but Windows 8.1 doesn't let to save .INI file in the folder that is in the Program Files/Program Files(86) folder. This is the new feature of the new MS Windows. My question is: how to beat it off?
There is no need to save files in program files. Use the configuration folder and it's sub folder.
