Demo restrictions: Signal lost after PC restart?
cjokl
Now Im trying Demo because considering buying full version. DVBViewer works fine. But after restart my PC - an error occurred. It looks like DVBViewer lost DVB-T signal. Signal is very low => all channels fluctuate between 0 and 20%, no any picture. I must rescan channels ("scan frequency" or "scan range") then all channels work fine again, signal is for 100%. The second option is: I must turn on and turn of my primary TV software (DVBDream). Then DVBViewer works without channels rescan.
I tried:
- Checked my DVB-T antena and cables (no problem)
- Checked last drivers for my TV card
- Updated VGA drivers, DirectX, audio drivers, codecs and OS via Windows update
- Export and after PC restart import channel list from *.ini file (still same error)
- Reinstalled operating system (clear new installation without others TV and multimedia software)
- Others TV programs (for ex. DVBDream) work correctly
I have:
- Windows7 Ultimate 64bit (My friend uses DVBViewer /I dont know version/ with same TV card on Windows XP 32bit without problems)
- Pinnacle TV card 710iX PCIe (only for DVB-T) but into DVBViewer is designated like Pinnacle 3010ix (as well as in DVBDream)
- nVidia GeForce 8600GT
- C2D 3,6GHz and 4GB RAM
Where is the problem? It is a demo feature? Thanks.
There is probably a conflict between two programs trying to use the same tuner. Do you have Media Center enabled as well?
3010ix is a dual tuner device - how many are seen by the application?
But I tried a new clean installation of Windows - only with DVBViewer. Media Center was disable I think ( I've never used it). Pinnacle 710iX has two digital tuners (DVB-T and DVB-S). I use only DVB-T. Here is screen from DVBViewer, DVBDream and Windows (driver).
There are a couple of WMC services that run unless disabled, or WMC is uninstalled.
Does DVBDream have any services running?
Maybe a clue here. Make sure the satellite tuner is disabled.
