hackbart Posted January 6, 2015 Author Posted January 6, 2015 @Gioxy: The older versions did not have had such an issue? I changed the output from GDI+ to DirectX. Christian Quote
Gioxy Posted January 7, 2015 Posted January 7, 2015 (edited) @ Christian: these are my findings on XP Sp3: - "JustRadio uninstall" from JustRadio's start menu folder doesn't find "unins000.exe" - v. 1.0.4.0 die just after his icon appear on the taskbar, without open any window - the equalizator cursors are inverted and all are managing the same (high) frequency range ...good hunting! Edited January 7, 2015 by Gioxy Quote
Residentcl Posted January 7, 2015 Posted January 7, 2015 (edited) Hello, here let some problems. Gioxy: - "JustRadio uninstall" from JustRadio's start menu folder doesn't find "unins000.exe" +1 Problem spectrum: http://youtu.be/DgEmsvCjLL8 and the other is missing Uninstaller Programs and Features: Greetings and Happy New Year to all! Edited January 7, 2015 by Residentcl Quote
hackbart Posted January 7, 2015 Author Posted January 7, 2015 The video is not working. You are right with the uninstaller. I will check this after i fixed an issue caused by older OSX builds which are not officially supported by Embarcadero. Quote
Residentcl Posted January 7, 2015 Posted January 7, 2015 It was a problem of law in the audio, so it was not possible to see in the UK. You should now see the video without problems, but no audio. Quote
hackbart Posted January 7, 2015 Author Posted January 7, 2015 Got it, i did not found the reason for this. I have the same issue sometimes here in the past. Actually the background is drawn on 3D Quad as texture and there was somehow the wrong back site of it painted. I've reuploaded a new binary with a fixed installer and the visualizer should also work like they should. Quote
Residentcl Posted January 7, 2015 Posted January 7, 2015 Nice update 1.0.5.4 , no problem now Missed the icon in Programs and Features, But it is a mere detail A DVBViewer did the same: http://www.DVBViewer.tv/forum/topic/55649-esthetical-bug-in-DVBViewer-pro-5320/#entry419345 Great job Hackbart Quote
hackbart Posted January 7, 2015 Author Posted January 7, 2015 nice to read. You mean the installer? Yes i did not added the icon yet, but will be available next release. Quote
Residentcl Posted January 7, 2015 Posted January 7, 2015 Do not read by the installer, but now that you mention it, it would not be a bad idea, it would be a nice touch. Quote
Gioxy Posted January 7, 2015 Posted January 7, 2015 @Christian Yup, uninstall and all visualizations work ok in v. 1.0.5.4 (with same cpu levels of previous v. 1.0.5.x)! I also noticed that, even when a visualization is activated, if you shrink the window so that only the station list remain visible, the CPU level falls down to less than 5%; otherwise, when a menu is rolled down, the CPU rises to 100% and the visualization refresh falls down - on my poor Pentium M 2GHz - to ~2 frame/sec... Anyhow the audio is always uninterrupted, and the "tuning in" speed is astonishing I hope you can find the time to take a look at the equalizer, now unusable... Keep up the good work! Quote
damley Posted January 8, 2015 Posted January 8, 2015 (edited) Glad to hear of new developments going on with justradio. Here is my CPU usage with XP SP3 (32-bit) AMD dual core 3.6GHz no visualization 25-30% With the visualizations the usage jumps up to 60% and more. This is with the latest justradio build 1.054. There is a problem with the new build, though, and the station names. Some of the characters are rendered incorrectly: With the earlier builds all the characters were rendered correctly. Edited January 8, 2015 by damley Quote
hackbart Posted January 8, 2015 Author Posted January 8, 2015 I'm barely able to see the image. Can you send me your channel list? The cpu usage should be below 4% the whole time, at least on systems >= vista. The application uses Direct3D 10 and 9 as fallback since December. Quote
damley Posted January 8, 2015 Posted January 8, 2015 (edited) Here's my dabradio.dat file. In 3 station names there is a square instead of a letter: SCHLAGERPARADIES radioBERLIN 88 8 FG_DJ_Radio_BRLN Also, in this last one I don't think there were underline marks in the name with the previous versions of justradio. DirectX 9c is the highest version of DirectX supported by XP, at least officially. There are reportedly hacked versions of DirectX 10 that work with XP, but I've never tried them. They aren't really 100% compatible, but maybe they would work with justradio? https://www.raymond.cc/blog/easily-install-and-download-directx-10-for-windows-xp dabradio.txt Edited January 8, 2015 by damley Quote
Tjod Posted January 8, 2015 Posted January 8, 2015 XP gets no security updates since nearly a year (ok there a hacks to let it look like a other version for POS terminals, but that will you only get updates for software which is installed on POS terminals). To make it short nobody shout use a XP pc with a connection to the internet any more. And a big part of Just Radio is about internet streams. So I think there is no need to addressed XP only problems in Just Radio. But it is Christians decision. Quote
damley Posted January 8, 2015 Posted January 8, 2015 (edited) Of course it's Christian's decision. But if that is the decision then it should be made known. For the record, DVBViewer works great with XP and I enjoy using it very much. I haven't experienced any problems and the program is incredibly versatile and configurable. I use Justradio mainly for listening to DAB radio. Same dongle as for DVB-T. It's not really necessary to install separate software to listen to internet streaming. Many (most?) streams you can listen to using your browser and maybe a flash plugin. Maybe a separate program like Justradio is more convenient for some people, but to me it's just icing on the cake. Anyway, that's my 2 cents. Edited January 8, 2015 by damley Quote
hackbart Posted January 8, 2015 Author Posted January 8, 2015 Thanks for the database, i will check it once i finished another subproject. I do not have any XP VM any longer, but i suppose i have an old Windows 2000 one somewhere on my backup drives. The speed issue is quite simple. Firemonkey tries to use DX10 Hardware and falls back to Software mode if any problem appears. I probably will add the ability to define the output mode via parameter. I will not create a version which does not use Firemonkey, since the original Justradio was designed for Mac and iOS platforms. I hope the DVBViewer will be able to play these stations and DAB sooner or later, but this will take time. What i'm currently working on, while i do not sit over the DVBViewer is a database editor/importer for the radio stations. I daily get new stations via mail and it is quite awful to hack them into the xml database. Not sure if the app will ever become available for public, but at least it should help me to keep the database up to date. Quote
damley Posted January 9, 2015 Posted January 9, 2015 (edited) Thanks for the feedback, Christian. I changed my screen resolution to get some better screenshots. Hope this helps. Normally the font for the station list is pretty small. The speed issue is quite simple. Firemonkey tries to use DX10 Hardware and falls back to Software mode if any problem appears. I probably will add the ability to ... Thanks for the background info. The good news is that Justradio never crashes because of the load. I'm excited about future developments - but, take your time. Hopefully you get a little fun out of it all! Happy programming Edited January 9, 2015 by damley Quote
hackbart Posted January 11, 2015 Author Posted January 11, 2015 Thanks, yes sure i'am. What i now have is a sql database with all my radio stations inside and connected with cities and regions - inkl. the information about which kind of radio transmission (am, fm, dab). I unluckily forgot that in usa there are a bunch of other transmission formats (like HD). I also wrote an exporter which creates the database justradio is using. The cool thing is that i'm able to add new stations at ease. I can either select the country or province resp. city i want to add a station. I'm also able to remove stations from this db more easy. The reason for this was that i daily get new stations which are a pain to add at the moment. Till now i used a huge xml file with all the channels inside in combination with notepad. Right now i can do this via sql commands Even if the app wont become public, its simpler to manage the stations which are right now (select count(id) from radios;) 25084. I did not added these pure internet stations to the database yet, which i kept up to date in a second xml file. Christian Quote
hackbart Posted January 26, 2015 Author Posted January 26, 2015 @Damley: The bug with the station names was quite nasty. By definition the maximum size of a descriptor is 16 bytes and the streams which have had weird characters at the end are always 16 byte in size. The reason is a missing #0 character at the end, which causes the utf8 decoder reading the text over the end. I will upload a fix later this week, once i finished updating the database manager tool. At the moment i add all the stations i received by mail since last year, which are a lot. Some of them are already inside the database, but some of them are not. Luckily i use a sql based system which detects double entries automatically. 1 Quote
hackbart Posted January 27, 2015 Author Posted January 27, 2015 Today i've submitted a new version of Just Radio mobile. It is a partial rewrite, caused by the experience i've collected while working with XCode and ObjectiveC in the last weeks. It is slightly faster, the cpu usage is probably lower (i measured this with the temperature of my iphone while betatesting in the gym) and it looks far more nicer than the previous builds. I also integrated it a bit more into the device. Sounds strange and means that i use the api to display the cover while playing a recognized song in the lock screen, fall back to the station logo if not and handle the volume regulator of a ear plug. I also thought about theming the background depending on the weather information in the region of the station you currently listening, but everything except blue (for cold) looked awful. So i dropped the idea for the moment, until i found handsome colors for white fonts (e.g cold is #30a0ff to#1060ff at the moment). Christian Quote
zypet Posted January 31, 2015 Posted January 31, 2015 I really like Just Radio, but: Norton Security deleted my "justradio.exe" because it detected a "Suspicious.Cloud.7.EP" ! Suspicious.Cloud.7.EP is a particularly nasty strain of virus and it can have some quite devastating knock on effects on your PC. Strictly speaking this high risk infection isn’t a virus, although it is often mislabeled as one. Whatever you choose to call it, you certainly don’t want it on your computer so let’s take a little closer look at what it is and how it works. Please fix as soon as possible Peter Quote
Tjod Posted January 31, 2015 Posted January 31, 2015 Ask Norton Security to fix there software If you version is downloaded from the Members Section my guess is a false positiv (regular bug in Antivirus software )https://www.virustotal.com/de/file/d8425c30cee5d1686992c84aada007ec31ae42f15c6636acfbca22eed29d0fe8/analysis/1422737037/ Quote
zypet Posted January 31, 2015 Posted January 31, 2015 As you mentioned - it was only a false alarm! Just Radio is still working again! Thx for information Peter Quote
refosk Posted February 22, 2015 Posted February 22, 2015 Just radio is super and I would be very happy if it have incorporated some kind of timer recording functionality or plugin for DVBViewer recording service. Quote
hackbart Posted February 22, 2015 Author Posted February 22, 2015 I might consider this, especially since programming a timer without kept the application running in background under osx is one of the issues i'm currently working on. 1 Quote
hackbart Posted March 23, 2015 Author Posted March 23, 2015 I've published the Webseite http://www.justradio.org. I still work on an update which comes with a real nice recorder. 1 Quote
Laserwave Posted March 30, 2015 Posted March 30, 2015 Thanks for this quite nice application! Trying the Windows version, I don't have a DAB card/stick, only a TV/FM radio PCI card. I see it works as an internet stream player which is great. After testing a few stations in my area (Greece), found that some play fine and several others not at all (like Kiss FM 92.9). Is this due to the absence of DAB? Thanks. Quote
hackbart Posted March 30, 2015 Author Posted March 30, 2015 No, this is probably because the link is a mms file and no regular shoutcast stream. I will fix the player in order to deal Microsoft formats too, right now i focused on Shoutcast and AAC/Mpeg2 transmissions. Next release will be able to play these streams. 1 Quote
Laserwave Posted April 7, 2015 Posted April 7, 2015 (edited) Thanks for your answer hackbart. A few suggestions for the excellent JR: a 'minimize to tray' option, ability to right-click the tray and browse/select a station from Favorites and also a mute option from the tray. About mute in the UI, it'd be nice if a single-click mute was possible (the left volume icon for example or a larger, more prominent icon) instead of having to use the slider. Another click would restore the previously set volume level. Edited April 7, 2015 by Laserwave Quote
Laserwave Posted April 10, 2015 Posted April 10, 2015 I'm getting a crash after about 2-5 minutes of listening to En Lefko 87.7 station (happened two times, never crashed with a few other stations I've been listening for much longer). Logs from AppCrashView attached. Just Radio logs.zip Quote
Mr. Man-wai Chang Posted April 24, 2015 Posted April 24, 2015 Suggestions and a bug report for JustRadio-1.0.5.7: 1. Tune To Last Station ("LastStation=" in justradio.ini) should be optional. 2. dabradio.dat should best be in text format, or maybe an XML file. 3. I would like to see an entry in option "DAB Scanner" for Hong Kong (frequency: 220.352). 4. Bug: DAB Radio does NOT appear in Root sometimes!!! Thank you for your attention! Quote
hackbart Posted April 24, 2015 Author Posted April 24, 2015 Yes a xml would be useful, at least for reading. I check the missing frequency. The bug has been fixed in the new version. Quote
Residentcl Posted August 13, 2015 Posted August 13, 2015 A favor if possible, add the option to also install the micro SD to the app from Google Play. Quote
Residentcl Posted August 13, 2015 Posted August 13, 2015 Today the app installer on Windows 10 and after a while without doing anything on the pc, I went out the below error: Quote
hackbart Posted August 14, 2015 Author Posted August 14, 2015 Weird, i made Tons of changes in the last months, and probably solved that issue. Just drop me a mail and i will send you the latest build. As you know i plan to publish a final build via justradio.org. The issue i stumbled on are just stupid eu related Problems with the VAT. 1 Quote
Radioman Posted August 28, 2015 Posted August 28, 2015 I have recently upgraded (?) from Win 7 64bit to Win 10. Now Just Radio does not work with DAB.Any hint of what to change or how to make it work, is appreciated.The program it self starts as normal, but when I choose one of the previously scanned DAB-channels, 'nothing' happens. BTW the DAB Player von Andreas Gsinn, does not work either. Quote
RC23 Posted August 28, 2015 Posted August 28, 2015 (edited) It is probable no help: Why don´t you build a dual boot system with Win7 and Win10? With a dual boot you have both possibilities Win7 and Win10 to explore. http://www.howtogeek.com/197647/how-to-dual-boot-windows-10-with-windows-7-or-8/ Edited August 28, 2015 by RC23 Quote
hackbart Posted August 28, 2015 Author Posted August 28, 2015 You need for both the driver for your dvb/dab stick. There is no magic if the driver is not working Quote
