Radioman Posted August 31, 2015 Posted August 31, 2015 You need for both the driver for your dvb/dab stick. There is no magic if the driver is not working I understand that. The question is which driver to use with Win 10? The one that I used for Win 7 does not work with Win 10. As a test I ran TransEdit and tuned to a DVB-T channel. TransEdit correctly detects the device. A scan gave this result: Quote
hackbart Posted August 31, 2015 Author Posted August 31, 2015 This can mean anything. Most likely is that the driver does not work. This would also cause the issue with the DAB+ inside JustRadio. Quote
hackbart Posted November 12, 2015 Author Posted November 12, 2015 Just a quick notice I've got a lot stations by mail in the last year, so i decided to update also the JustRadio Desktop Version. As you know besides the Windows version, we also offer a OSX build. The screenshot shows the current state of the version: I changed a lot inside the UI in order to have a look and feel which is more OSX- resp. Windows-ish. 95% of the 67000 Radio Stations do not have high resolution logos, so i decided to create an algorithm which renders a good looking background. I calculate the main color of an image (by transforming the RGB color to HSV) and render a fractal with this color. The result looks awesome, even with extremely poor channel logos (smaller than 82x82 pixel). By the way everything you see (except the channel logo) are no real images at all. I completely got rid of them and use SVG like Vectordata. This might be not the fastest way, but if you scale the window on an iMac5k you see the difference. The player now comes with a small control window, and the already known bigger one. I also made a separate recording window, which allows to save unlimited amount of radio stations at the same time. The UI for this page is not complete, so i don't post a screenshot. Anyhow it runs nicely here and you can easily increase your audio library in this way. Christian 2 Quote
hackbart Posted November 13, 2015 Author Posted November 13, 2015 Right now the recorder looks like this: Maybe somebody has a few suggestions for improvement. I want to keep it as simple as possible. There will be a selection which shows all recorded stations, but overall i want to keep it as clean as possible. The idea is to select the most favorite stations which are recorded the whole time. I don't want to offer timed recordings. Since there is no epg at all i don't see any reason for. And if you keep in mind that a radio station record for 24h is smaller than 2 hours of regular tv recordings there is no real need for. Quote
notaclue Posted November 17, 2015 Posted November 17, 2015 Hi Christian, just installed v1.0.5.7. Cosmetic problem: The version info (Hilfe - Über Just Radio) states it is still v1.0.5.4. Functional problem: Can't get french stations to work. No error, no sound. E.g. Try France Inter in Paris Region. Can you confirm this problem? Thanks. Chris Quote
hackbart Posted November 17, 2015 Author Posted November 17, 2015 Hi, well the database in the current public version is not updated yet. I tested them here and they run nicely with the new database. Christian Quote
notaclue Posted November 18, 2015 Posted November 18, 2015 Ah, okay. Please keep us informed when you publish a new version, where these stations start working again. Or is there a way to manually update the database from v1.0.5.7 in order to fix this? Quote
hackbart Posted November 18, 2015 Author Posted November 18, 2015 I have to update the file on the server. Till then i need find a memory leak and an issue which causes a crash on certain machines. Quote
notaclue Posted November 18, 2015 Posted November 18, 2015 Okay, thanks for the info, it makes sense to fix the bugs before publishing a new version. Good luck with that! Quote
hackbart Posted November 18, 2015 Author Posted November 18, 2015 Maybe you can translate the following lines into french? I have English, German, Spanish, and Italian so far. Root About Just Radio Hide Just Radio Hide Others Show All Quit Just Radio Favorites Sleep Timer Sleep Timer off Sleep Timer in %s min Map Add To Favorite Delete From Favorite Stations Search Window Artist Cover Find Song in iTunes Fullscreen Spectrum Disabled Waveform FFT Logarithmic 3D Services Help Minimize Window Zoom Controls Play Pause Record Stop History Found Channels: %d Current Ensemble: %s Create new Station &Station: &Description:* &Country: &City: &URL: &Logo-URL:* Send Cancel &Split by Title Played Songs Config Folder Stream not available! Equalizer... Fluid Dynamics Check for Updates... A new database version is available. Do you want to update? Yes No Add Delete Ok Recorder... Tracks Recordings Recorded: %0.2fMB (%0.2fMB/s) Volume Up Volume Down Mute Current Song Received Status DAB Scanner Mini Player Quote
hackbart Posted November 18, 2015 Author Posted November 18, 2015 Really? Auntie Google made translations are extremely awful. I made the fun with crosschecking the german translation and it was Quote
Residentcl Posted November 18, 2015 Posted November 18, 2015 Hackbart actually use Google Translate? Quote
notaclue Posted November 18, 2015 Posted November 18, 2015 Maybe you can translate the following lines into french? I have English, German, Spanish, and Italian so far. Sorry, french is not my first language. Understanding it is not the same as expressing yourself in it... I don't think I'm qualified. Any french nationals here in the forum? Quote
Residentcl Posted November 18, 2015 Posted November 18, 2015 Translate Spanish 1.0 Añadir a FavoritoEliminar de FavoritoEstacionesBuscarVentanaImagen del artistaEncuentra la canción en iTunesPantalla completaSpectrumDeshabilitadoWaveformFFTLogarithmic3DServicesAyudaMinimizar ventanaZoomControlesPlayPausarGrabarPararHistorialCanales encontrados: %dTema actual: %sCrear nueva Estación&Estación:&Descripción:*&País:&Ciudad:&URL:&URL de la imagen:*EnvíarCancelar&Dividir por títuloTemas anterioresCarpeta de configuración¡Señal no disponible!Ecualizador...Fluid DynamicsBuscar actualizaciones...Una nueva versión de la base de datos está disponible. ¿Quiere actualizar?SiNoAñadirEliminarOkGrabar...TemasGrabacionesGrabar: %0.2fMB (%0.2fMB/s)Subir VolumenBajar VolumeMutePrograma/tema actualRecibidoEstadoEscáner DABMini Reproductor 1 Quote
notaclue Posted November 19, 2015 Posted November 19, 2015 Maybe you can translate the following lines into french? I have English, German, Spanish, and Italian so far. Ok, here goes. Any french natives, feel free to correct me! Racine A propos de Just Radio Cacher Just Radio Cacher autres Montrer tous Quitter Just Radio Favoris Compte à rebours Désactiver compte à rebours Compte à rebours dans %s min Carte Ajouter aux favoris Enlever des favoris Stations Chercher Fenêtre Couverture Chercher titre dans iTunes Plein écran Spectre Désactivé Ondulation FFT Logarithmique 3D Services Aide Minimer Fenêtre Zoom Contrôles Lecture Pause Enrégistrer Stop Histoire Trouvé stations: %d Ensemble actuel: %s Ajouter nouvelle station &Station: &Description:* &Pays: &Ville: &URL: &Logo-URL:* Envoyer Annuler &Partager par titre Titres joués Repertoire de configuration Stream pas disponible! Equalizer... Dynamique de fluides Mise à jour Une nouvelle version de la base de donnés est disponible. Voulez vous une mise à jour? Oui Non Ajouter Effacer Ok Enrégister… Titre Enrégistrements Enrégistré: %0.2fMB (%0.2fMB/s) Volume + Volume - Muter Titre actuel Reçu Condition DAB Scanner Lecteur miniature Quote
notaclue Posted November 19, 2015 Posted November 19, 2015 base de donnés First mistake. Should be "base de données". Quote
hackbart Posted November 19, 2015 Author Posted November 19, 2015 thanks, i updated spanish and added french resp. chinese Quote
notaclue Posted November 19, 2015 Posted November 19, 2015 Christian already has this, thought it might also be of general interest: Here is a PDF from Radio France with all the direct links to their radio streams, both in low quality and medium quality. Found it while googling a medium quality link Christian had found and sent me. HTH www.radiofrance.fr/sites/default/files/pages_uploaded_files/radio_france_-_adresses_flux_mp3_-_mai_2015.pdf Quote
hackbart Posted December 7, 2015 Author Posted December 7, 2015 The final build is now available for download at http://www.justradio.org. I thought it would be available in the same time with the apple version, but apple has the application in review since 5 days. Not sure why a update will take so long, but from the coding point of view it was a complete rebuild Christian Quote
Residentcl Posted December 7, 2015 Posted December 7, 2015 Nice Christian PD: checks the mail... Quote
Tjod Posted December 7, 2015 Posted December 7, 2015 @Christian In Firefox I get a 'justradio.exe' and not justradio.exe Quote
hackbart Posted December 7, 2015 Author Posted December 7, 2015 hmm, maybe a script issue. You can find the file under www.justradio.org/files/justradio.exe. Christian PS: Yepp, was a bug in the download script. PPS: I will also sign the binary with a valid certificate. Quote
Tjod Posted December 7, 2015 Posted December 7, 2015 And the Terms page on http://www.justradio.org/ has a bug. If you are on the Terms page, Home, Features and Order aren't working. Quote
hackbart Posted December 7, 2015 Author Posted December 7, 2015 Thanks for the feed back. The OSX build passed the review (after 5 days of testing). I will fix the terms page just while writing these lines. Christian Quote
Residentcl Posted December 10, 2015 Posted December 10, 2015 Date for the new version for Android? Quote
David- Posted December 10, 2015 Posted December 10, 2015 (edited) checked "Spectrum" but nothing appears/happens. Map is deactivated. Souldnt it be shown behind the station-logo? Using Win 8.1 (AMD GPU) Edited December 10, 2015 by David- Quote
hackbart Posted December 10, 2015 Author Posted December 10, 2015 Yes it should show up, but it seem to be that not always. I will check that out and reupload the binary. I've reuploaded the binary. While the debug version works fine, the release did not in this certain case. Christian Quote
Residentcl Posted December 10, 2015 Posted December 10, 2015 (edited) True, I have only 3D. Windows 10 Build 10586 (v1511/th2) 64 bit. AMD Radeon R7 200 Series. Radeon Software Crimson Edition 15.11.1. Edited December 10, 2015 by Residentcl Quote
hackbart Posted December 10, 2015 Author Posted December 10, 2015 The problem is only under windows and only in the release mode. This was an issue in the older build too, until i rewrote the code. I thought this problem was gone while using Delphi XE10. Therefore i used XE5 and it seem to be compiler related. Running the same build on OSX i don't have this problem. I will check it out in detail, later today The Android build will be updated, once i found a way to restore my playstore .keystore file. Never loose this file, because you won't be able to upload updates without What i can do is to update the database on the server in order to get rid of obsolete stations. Addentum: It seem to be compiler related, because the "reason" for the behavior is this code: procedure FillDWord(var Dest; Count, What: Cardinal); assembler; begin asm mov EDI,Dest MOV ECX,Count MOV EAX,What CLD REP STOSD end; end; Somehow it does not only fill the dest pointer - at least not if i compile under release mode Christian Quote
David- Posted December 15, 2015 Posted December 15, 2015 Spectrum now works fine. Is it possible to integrate some kind of update-info or function? This is missing in DVBViewer too. Quote
hackbart Posted December 18, 2015 Author Posted December 18, 2015 What do you mean with update info? For the application? I will consider this for one of the next releases. Right now you have the database update function. Did somebody realized that it is possible to record unlimited amount of stations and the records are splitted if possible automatically. Christian Quote
Residentcl Posted December 18, 2015 Posted December 18, 2015 I think it says the option of adding new application updates in the "About Just Radio" In DVBViewer I never left me notice if there is new version of the application About DVBViewer Pro, Did somebody realized that it is possible to record unlimited amount of stations and the records are splitted if possible automatically. Yes Update Translate Spanish 1.1: DAB Scanner: Escanear DAB Check for Updates...: Buscar actualizaciones de radios... A new database version is available. Do you want to update?: Una nueva actualización de radios está disponible. ¿Quiere actualizar? Equalizer...: Ecualizador... Quote
hackbart Posted December 18, 2015 Author Posted December 18, 2015 Thanks, the next version will have an update notification. What does "a new version is available." mean in spanish? Una nueva versión está disponible. Quote
Residentcl Posted December 18, 2015 Posted December 18, 2015 Example: That came a new version of the application. Quote
hackbart Posted December 18, 2015 Author Posted December 18, 2015 I've published a new version. This one shows a red text field in the about window, if there is a new version. I also fixed a problem while saving the favorites at the end. Under certain circumstances it simply did not stored added favorites. Quote
hackbart Posted December 23, 2015 Author Posted December 23, 2015 I've added the ability to use Sonique Visualizer Plugins The same code is inside the pro version, so adding it was quite easy. Since i use DirectX for rendering it is extremely fast. Will be in the new update (probably tomorrow). Christian Quote
hackbart Posted December 24, 2015 Author Posted December 24, 2015 I've uploaded a "x-mas" release with a few more stations added and support for sonique visualizations. Christian Quote
Residentcl Posted December 24, 2015 Posted December 24, 2015 Good update, No more problems with Spectrum This one shows a red text field in the about window, if there is a new version. The other version "5.0.0.5" I get no notice of the new version Quote
