crown08 Posted July 25, 2014 Share Posted July 25, 2014 Good evening, I have a problem when I use RS api. When I try obtain the channels with getchannelsxml.html option, I receive only the text Template not prepared! or the principal page without styles. When I use getchannelsdat.html I obtain the correct result, other funtions work well too (version.html for example) I need use getchannelsxml.html because the XBMC PVR addon use this function for obtain the channels. I only want ask if is a problem or can I have some solution for this? My platform is windows 8.1. I attach support.zip file too. Thanks for your attention. support.zip Link to comment
Tjod Posted July 25, 2014 Share Posted July 25, 2014 Is the local DVBViewer Pro working correctly as RS Client? http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer Link to comment
crown08 Posted July 25, 2014 Author Share Posted July 25, 2014 Hello and thanks for the quick reply, I configure now the DVBViewer Pro with RS 1.29 and work well. It recognize the tunner how network tunner and I can see the channels well but when I put in the navigator (Chrome or IE) the petition I obtain that the Template not prepared text. The pettition that I put is http://user:pass@127.0.0.1:8089/api/getchannelsxml.html or with localhost. Thanks. Link to comment
Tjod Posted July 25, 2014 Share Posted July 25, 2014 With getchannelsxml.html you get a xml file not a web page, this is correct. This is not made for displaying in the web browser (even if it is possible). It is made for being parsed by a program. Link to comment
crown08 Posted July 25, 2014 Author Share Posted July 25, 2014 Hello and thanks, I enabled the DVBViewer PVR for XBMC and obtain the next error Unable to parse channels. Invalid XML. Error: Warning: No XML tag found I think that is because the application don't receive a correct xml file, receive the html with the text. I make a java program with HttpClient for do the same request that XBMC http://user:pass@127.0.0.1:8089/api/getchannelsxml.html?subchannels=1&rtsp=1&upnp=1&logo=1 and I receive the next response <html><head></head><body>Template not prepared! </body></html> Thanks. Link to comment
Tjod Posted July 25, 2014 Share Posted July 25, 2014 If you open the web interface this work correct? Do you have all channels in there? Link to comment
crown08 Posted July 25, 2014 Author Share Posted July 25, 2014 Hello, no, when I open the web interface, only inthe timeline tab work ok, I can see all the channels, but in TV Guide Tab, when I change the combo, I lost the channels and in Channel EGP Tab and Search EGP Tab, I can't see any channel only I can see TV an Radio options. i don't understand how is the problem?? Thank for your help. Link to comment
Tjod Posted July 25, 2014 Share Posted July 25, 2014 Currently I have no idea what is causing your problems. Link to comment
crown08 Posted July 25, 2014 Author Share Posted July 25, 2014 Good night, I think that I resolve the problem, it is the use of System user in RS Service. I change the user for the service from System to user account with administrator priviledges for start service session and work correct now. Thanks for all. Link to comment
