McenterFreak Posted July 27, 2014 Share Posted July 27, 2014 I am on holliday, and i want to reach my RS with DVBViewer. I har forwarder port 8089 in my router and added this port in my firewall on the RS machine. I can reach RS webpage without any problem, and if i press Test connection in DVBViewer it is fine. But i cant Watch any channels. It says No Hardware Link to comment
Tjod Posted July 27, 2014 Share Posted July 27, 2014 The DVBViewer is not designed to stream though the internet. It uses a lot more ports and has no access protection on thoughts services. (and some used protocols are not routable though the internet if I'm right) So it is a bad idea to open this ports from the internet. A solution could be a VPN server at home. But only if you have a fast enough internet connection 8 MB/s (15 MB/s for HD) upstream or more (the mostly faster downstream is not relevant) Bout you can try the streaming via Web-interface (if ffmpeg.exe is in the RS folder). Click on a channel logo > start stream. Link to comment
McenterFreak Posted July 27, 2014 Author Share Posted July 27, 2014 I have tried to use streaming through the webinterface, but its not stable. It runs for a few minutes, then stops Link to comment
Tjod Posted July 27, 2014 Share Posted July 27, 2014 Not sure what causes this problem. Maybe reducing the bit rate helps. Link to comment
