stefmeister2010 Posted August 15, 2014 Posted August 15, 2014 (edited) HI, I've been using DVBViewer Pro successfully for a few months now & not had any problems at all. However I came to start it yesterday & during the loading screen it frooze on 'loading service channel list', I left it for a while yet it did not go past that screen. I read somewhere that this was something to do with the recorder service, However I have never had that installed & have never used it so its never been enabled in the main program. I then came here & downloaded the latest version, After the initial setup procedure I got an access violation error when the wizard was starting but was able to continue through that & eventually after ticking the 'start DVBViewer' box after the wizard was done DVBViewer did start & work as normal. However after I closed it once I'd finished using it & came to use it again later on I am back to the same problem, It gets stuck on the 'loading service channel list' during the startup. I did a full uninstall of the problem & deleted the program & user folders & did a full reinstall. As yesterday I got the access violation when the wizard started but was able to ignore that & get the program to load & work as normal but again after closing it I'm back to the same problem. Here is what the DVBViewer.log shows: http://pastebin.com/b3Zr6LpM The version I have installed now is the latest available in the members area (5.3.1). Just to add my system specs, I'm running Windows 7 x64, 8Gb Ram, AMD Athlon X4 955 3.2Ghz, & my C drive is a 120Gb Samsung SSD 840 Series. My DVB-S card is an old SkyStar 2. Everything else on my system seems to be working fine, No new hardware has been installed & nothing has been removed. Edited August 15, 2014 by stefmeister2010 Quote
