Hauppauge PCTV Triblestick 292e compatible with DVBViewer
Gaio
Hey
As subject says, is Hauppauge PCTV Triblestick 292e compatible with DVBViewer ?
Im trying to make DVBViewer to find out if i should buy it, but i cant make it search for channels as it says no hardware is installed.
So how do i make it see my TV Tuner ?
It is installed in device manager and shows as "PCTV 292e" and the PCTV program kan find and use it.
So is it compatible or what do i do ?
Thanks in advance
Michael
It seams there is a DVB-C DVB-T2 Hybrid chip which need a special treatment and is not supported by the DVBViewer.
http://www.DVBViewer.tv/forum/topic/55243-dvbv-doesnt-find-channels/
http://www.DVBViewer.tv/forum/topic/54366-delock-dvb-t-c-hybrid-stick-funktioniert-nicht/
http://www.DVBViewer.tv/forum/topic/53652-dvb-c-stick-wird-nicht-erkannt/
An as far as I know there is currently no effort to change that.
So every one should be careful with DVB-C DVB-T2 Sticks in combination with the DVBViewer.
Well the in the first link, he says that he can scan with it :
I am using PCTV 292e tuner and tried few days to scan cable channels without any kind of success.
So he must have made it work, but how ?
As far as I understand he had no success with the DVBViewer.
Only "TVCenter 6" a different program seem to work.
So will the PCTV 292e tuner be added to DVBViewer's compatibility list ?
  • 2 months later...
Got a PCTV Systems DVB-T2 292e the other day and it works ok with DVBViewer for UK Freeview HD
Also use a dvb-t2 290e and a WinTV-NOVA-TD
