Be careful with Kaspersky Antivirus 2015 (15.0.0.463) !
Beachmol
Hello,
I was using DVBViewer Pro 5.2.9.0 and Kaspersky Antivirus 2014 and all was working perfectly.
After installing Kaspersky Antivirus 2015 (15.0.0.463), DVBViewer has begun to be very very long to start (more than one minute !) and change a channel takes more than 6 seconds ! (it was before 5 seconds to start and 2 seconds to change a channel)
Thinking it was because my software was not the last release, i downloaded DVBViewer Pro 5.3.1.0 but the problem was still present !
After several tests, i've finally found it was Kaspersky Antivirus 2015 the problem ! i removed it and installed Kaspersky Antivirus 2014 and the problem was gone !
So, if you have your DVBViewer very slow, first, try to disable your antivirus and/or check if it's not from where your problem come from !
Sincerely.
Philip.
Reminds me of a security software test (not Kaspersky) in a German computer magazine, with the conclusion "This software causes so many harmful effects that there is no need for malicious software anymore". :)
  • 1 month later...
There is a similar topic on kaspersky forum but regarding Photoshop. Version of KAV 15.0.1.415 resovle problem in both aplication ( including DVBViewer ).
