Lockups in RTSP streaming since 1.30.x
bccrew
Hello,
I'm experiencing lockups in RTSP streaming since the latest 2 beta's.
I'm using a Server with RS 1.30 with 1 dvb-s and 3 dvb-c tuners. Streaming an unencrypted channel to one of the DVBViewer clients causes an occasional freeze.
The image just hangs on a frame, DVBViewer does not crash, nor does the RS. I can just close DVBViewer and reopen it again and the streaming continues without problems.
The lockup happens about 1 time every hour.
Anyone else experiencing this?
Should I try to play with the RecvBuffer value?
Noone with same issue? How can I debug this?
..does it matter if you switch from UDP to TCP?
I don't have this option in V5.3.1.0... :(
Click on DVBViewer Media Server and the option should appear.
(This is only necessary once, if the RTSP device is generated in a older DVBViewer version)
Stupid :glare:
I will try it thanks :D
