offlinefreaks Posted December 15, 2014 Posted December 15, 2014 Hi i have tried to install this recording service i have everything installed DVBViewer 5.3.2 i have sky star 2 PCI card running on windows 8.1 x64 every version of RC i have tried to install it shows same error "Please install the current version of DVBViewer Pro first." I tried changing folder paths by copying DVBViewer folder to c: and to c:\Program Files\ , also tried running in compability mode but nothing works. Can someone help me ?
Tjod Posted December 15, 2014 Posted December 15, 2014 Run the DVBViewer Pro setup again. And the don't change the folder in the RS setup. It has to be the same as in the DVBViewer pro setup.
offlinefreaks Posted December 15, 2014 Author Posted December 15, 2014 (edited) I tried that already it didnt work. I cant change anything in RS install becuse i cannot run it as soon as i run it shows me message like i described. Edited December 15, 2014 by offlinefreaks
Tjod Posted December 15, 2014 Posted December 15, 2014 Remove the stolen DVBViewer version completely (including all configuration and changes made to your system by the pirated version you are currently using). By a legal DVBViewer Pro Version and install it. And then try installing a legal Recording Service Version.
offlinefreaks Posted December 15, 2014 Author Posted December 15, 2014 I already tried that in the first place, that is the reason for this version of DVBViewer that i have now becuse i tried numerous versions from net man i think i tried every version of DVBViewer that i could find and always same result, cant install this RS....
offlinefreaks Posted December 15, 2014 Author Posted December 15, 2014 I deleted EVERYTHING installed again this http://www.DVBViewer.com/en/index.php?page=demo again the same result here is support support.zip
offlinefreaks Posted December 15, 2014 Author Posted December 15, 2014 is it possible to work with this version DVBViewer TE2 1.0.4 it came with driver cd?
Tjod Posted December 15, 2014 Posted December 15, 2014 The only legal way to get the Recording Service is to by the DVBViewer Pro. http://en.DVBViewer.tv/wiki/Terms_of_Use_Recording_Service https://www.DVBViewer.tv/members/ You are trying to install a pirated Recording Service version.
offlinefreaks Posted December 15, 2014 Author Posted December 15, 2014 OK Thank you for your help much appreciated.
