Overlaping recordings
Tyro
I have 2 decoders so it´s possible to record 2 channels at the same time, but if I have one channel that overlaps another one in the recording service, only the first one will be recorded. I can look at one channel and record another channel, so both decorders works fine. Why can´t recording service start to record the overlaped channel on the second decoder?
Stop the Recording Service (Icon get grey).
In DVBViewer options > hardware > and change the status of one tuner to don't use. And try to receive a channel. Than set this tuner to normal and the other one to don't use. And try to receive a channel.
If it works start the Recording Service and run the "Recording Service Setup Wizard"
http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer
