Berchemer Posted January 8, 2015 Posted January 8, 2015 It would be fine, if you would add a One-Click-Button in the right part of the timer list inside the recording service.Would be something like the One-Click-Delete-Button which is already part of the timer list.By now you have to click the timer event, toggle between active and not active inside the popup window and save the timer event.Thanks in advance and thanks for your previous work for the recording service :-)
