ThaHandy Posted January 11, 2015 Posted January 11, 2015 Hi,I've the feeling this has to do due to I'm using a network tuner "Silicondust HDHomeRun HDHR3-4DC Tuner" adding that extra load on the OS (kernel time). Because when I'm using the PCI tuner there are mostly no errors.This issue mostly occur when the recording service is busy in the background, ie. starting/stopping a record or me using the Recording Service webGUI.----------------------------------------------------------------------------------Device: Silicondust HDHomeRun Tuner 14103C38-0 (2)23:40:04 / 0:00:00 (~ 0,00 MB) Start23:40:06 / 0:00:02 (~ 1,31 MB) PID 7611: H.264 Video, 16:9, 1920x1088, 25 fps23:40:06 / 0:00:02 (~ 1,31 MB) PID 1102: MPEG Audio J. Stereo, 48 khz, 192 kbps23:40:06 / 0:00:02 (~ 1,31 MB) PID 7617: MPEG Audio Mono, 48 khz, 192 kbps23:45:28 / 0:05:23 (~ 317,24 MB) Errors: 20:02:54 / 0:22:50 (~ 1347,23 MB) Errors: 30:02:55 / 0:22:51 (~ 1348,27 MB) Errors: 11:20:00 / 1:39:55 (~ 5902,63 MB) StopAverage Data Rate: 0,984 MB/sTotal Size: 5902,6 MB (6189361004 Bytes)---------------------------------------------------------------------------------Setting the priority to high seems to help a bit, but the issue remains.Any ideas? 2
bccrew Posted January 12, 2015 Posted January 12, 2015 This is not very serious imho. I'm recording from cable daily and I have errors in almost every recording.. 20:14:00 / 0:00:00 (~ 0,00 MB) Start20:14:01 / 0:00:01 (~ 0,76 MB) PID 307: H.264 Video, 16:9, 1920x1088, 25 fps20:14:01 / 0:00:01 (~ 0,76 MB) PID 607: MPEG Audio Stereo, 48 khz, 256 kbps20:14:01 / 0:00:01 (~ 0,76 MB) PID 707: MPEG Audio Stereo, 48 khz, 256 kbps20:40:11 / 0:26:11 (~ 1404,58 MB) Errors: 120:54:03 / 0:40:02 (~ 2151,78 MB) Errors: 220:54:42 / 0:40:42 (~ 2187,21 MB) Errors: 220:59:24 / 0:45:23 (~ 2440,07 MB) Errors: 121:03:04 / 0:49:04 (~ 2638,19 MB) Errors: 121:33:46 / 1:19:46 (~ 4266,64 MB) Errors: 121:52:00 / 1:38:00 (~ 5249,86 MB) Stop These can just be simple AC3 frame errors or little discrepancies in the signal. I hardly see them when I view the recording later..
Derrick Posted January 12, 2015 Posted January 12, 2015 ..there are no AC3 frames, and yes, it is serious!
ThaHandy Posted January 13, 2015 Author Posted January 13, 2015 (edited) The errors I have are real errors. The video is glitching for a split second if i check on those times.Recordings can be flawless as long i don't touch the service.(i have 100% signal) Below is a recording of 12 hours!Device: Silicondust HDHomeRun Tuner 14103C38-0 (2)6:40:02 / 0:00:00 (~ 0,00 MB) Start6:40:03 / 0:00:01 (~ 0,13 MB) PID 7611: H.264 Video, 16:9, 1920x1088, 25 fps6:40:05 / 0:00:02 (~ 1,18 MB) PID 1102: MPEG Audio J. Stereo, 48 khz, 192 kbps6:40:05 / 0:00:02 (~ 1,18 MB) PID 7617: MPEG Audio Mono, 48 khz, 192 kbps11:35:50 / 4:55:47 (~ 17474,48 MB) Errors: 218:20:00 / 11:39:57 (~ 41352,28 MB) StopAverage Data Rate: 0,985 MB/sTotal Size: 41352,3 MB (43361009208 Bytes)To bad the recording service and the web service are one deal. otherwise I'd kicked the webserver to idle. Edited January 13, 2015 by ThaHandy
ThaHandy Posted January 15, 2015 Author Posted January 15, 2015 So, any info how rs is dealing with the data? Where the lag can be? Any debug info?
Piers Posted January 27, 2015 Posted January 27, 2015 I've noticed recording errors when using the RS to record, using another application there are no issues with streams. However, it's still a very impressive application and worth the money.
