Riodda Posted March 3, 2015 Posted March 3, 2015 I've generated a very long favourites list when i open it i see that the list does not scroll donw when i approach the end of the list neither it opens on 2 columns, see atached picture. I'm in a 2 screen configuration (resolutions are a bit different). Quote
Tjod Posted March 24, 2015 Posted March 24, 2015 I can confirm it.On the Screen with the lower vertical resolution you cant see the end of the list. It has the same length on both screens. But most likely there will be no fix. The problem is not in the DVBViewer Code. The menu is handled by the Delphi VCL and Windows API. Quote
