recorder autostart?
Young Vanish
Sorry if this is answered elsewhere, if it is I couldn't find it.
DVBV on PC running Windows 8.1
The first recording I set up was a few days in advance, the recorder didn't kick in and I missed what I wanted.
Tried another test recording with DVBV running and the recording worked as expected. Migrating from Hauppauge WinTV this is not what I expected (that recorder kicks in without the viewer loaded)
So . . . I set DVBV to autoload at boot time (into a minimised window).
Scheduled recordings now take place, but DVBV will not launch from its minimised state in the task bar. Neither will it close, I am forced to use 'End Task' from the Task Manager.
At that stage I can launch DVBV from it's shortcut on my desktop.
I have now had to stop DVBV on the startup programs list, and remember to launch it if I have any recordings scheduled for that date.
Are there some settings I'm missing somewhere? Or is this the way it works?
Thanks for the replies.
Does either of these options have advantages/disadvantages over the other?
Searching the forum I've found a previous answer . . .
"If you want just wake up the pC for recording then Task Scheduler is it.
If you want network streaming to mutliple PC, UPnP/DNLA, a webinterface then use Recording Service."
Thanks
