annibal Posted April 9, 2015 Posted April 9, 2015 hello thereI purchased DVBViewer Pro installedI tried to do the recordings, however if manual register then everything works if for example I program a recording and the channel is connected to another as part of the registration does not change channels automatically and the recording file remains of a few kbthere is a solution to this ??thanks for your helpgood evening Quote
Tjod Posted April 9, 2015 Posted April 9, 2015 Please post a support.zip to chec for configuration problems. Quote
annibal Posted April 11, 2015 Author Posted April 11, 2015 hello I'm new here and I did not know how to move here's support.zip I hope I'm doing wellsupport.zip Quote
Tjod Posted April 11, 2015 Posted April 11, 2015 You have the Recoding Service installed. But the DVBViewer is not configured to work with the Recording Service. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer This can be the reason for your problem. Quote
annibal Posted April 11, 2015 Author Posted April 11, 2015 hello thanks for your response Now I've configured everything as described in the guide and when I turn on the recording DVBViewer automatically recording starts on the RC But the problem is that here are a few kb file log another question then you can record two channels simultaneously, one free and the other encrypted channel '? thanks for your answers2015-04-11_18-44-11_Premium Mya_prova.log Quote
Tjod Posted April 11, 2015 Posted April 11, 2015 OK I overlooked one thing remove the "Has CI" on the tuner which is not connected to the CI. (RS options) http://en.DVBViewer.tv/wiki/Options_Service_-_Hardware#Has_CI_module If that doesn't fix the problem pleas try it first with unencrypted channels only du you have problems there? Quote
annibal Posted April 11, 2015 Author Posted April 11, 2015 I felt like I've described is the problem continues channels in clear records but known such discontinuities in the signal even if I have no problems in the channel that I'm recording Quote
Tjod Posted April 11, 2015 Posted April 11, 2015 You should try removing the CI if you still get discontinuities it is by DVB-T mostly a reception problem. Quote
annibal Posted April 11, 2015 Author Posted April 11, 2015 is no reception problem because I see in DVBViewer channel well and only when that happens register while in encrypted channels continues to be a few files kb What do you recommend I uninstall everything and I only install DVBViewer ?? I am only interested scheduled recordings and I could do it just with DVBViewer But there is always the same problem that does not change the channel recording Quote
Tjod Posted April 11, 2015 Posted April 11, 2015 So not encrypted channels have no problems at all. right? Rename the Plugins Folder in the DVBViewer directory to Pluginsoff, so that no plugis are used at all. Before future testing with encrypted channels. Quote
annibal Posted April 11, 2015 Author Posted April 11, 2015 here is the example from the images I reinstalled everything is the DVBViewer that RC but the problem continues I renamed the folder pluginoff but also that of the images are the results I need to register in another channel and instead does not change channels even if the recording part and the end result is unreadable file but if I try to record from RC 1 file goes to fruition while others block a few and is a continuous series of files from a few kb Quote
Tjod Posted April 11, 2015 Posted April 11, 2015 You are using a dual turner DVB-T stick. Therefore you can record all unencrypted channels from two transponders (frequency). That are around 8 channels. Only if you are recording at least two channels from different transponders the the one used for main playback the channel for playback will be changed. Are two antennas connected to the DVB-T stick? are they in the same position? Test both tuners separate. Set one tuner in the RS to don't use (options > Hardware). And look if playback works. Then set the second to don't use and the firs to normal and test again. Quote
annibal Posted April 11, 2015 Author Posted April 11, 2015 hello no only has one antenna connected has only one antenna input here are the results support.zip Quote
Tjod Posted April 11, 2015 Posted April 11, 2015 Then you need to set the tuner without a antenna to don't use in the RS options > hardware. And you have not followed thus instructions: You have the Recoding Service installed. But the DVBViewer is not configured to work with the Recording Service. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer This can be the reason for your problem. Quote
annibal Posted April 12, 2015 Author Posted April 12, 2015 I amI then reinstalled everything and follow any guideNow I installed the program without RCthe problem is identicalregistration does not change the channel here is the relationship support.zip Quote
Tjod Posted April 12, 2015 Posted April 12, 2015 You need to set the tuner without a antenna to don't use in the DVVBViewer options > hardware. Quote
annibal Posted April 12, 2015 Author Posted April 12, 2015 sorry I did not understand what I should set you can tell me exactly what to do ?? thanks Quote
annibal Posted April 12, 2015 Author Posted April 12, 2015 if you're referring to the highlighted image that is the cam CI to see the encrypted channels Quote
Tjod Posted April 12, 2015 Posted April 12, 2015 Set State of the tuner without antenna "Do not use" http://en.DVBViewer.tv/wiki/Options_Hardware#State Quote
annibal Posted April 12, 2015 Author Posted April 12, 2015 hello thanks for your answers configure server windows linux debian etc but to configure the DVBViewer I know that it is not possible because in the past I've used this program with the same tuner installed and with the same parameters and have never had problems Now it all seems much more complicated being a paid program should not work just installed ?? has more than 3 days I'm trying to set it without any positive result, and as if a person buys a car and just take it to a mechanic must exit I think the program should work just installed as it was before without the need for all of these configurations however if you kindly some files that I do go and change the program I'm grateful otherwise I threw only € 20 for a program not working this is my opinion have a nice day Quote
Gioxy Posted April 13, 2015 Posted April 13, 2015 (edited) IMO Tjod insist on request you to set to "do not use" the receiver without antenna because I suppose he think (as I do...) you have got that kind of dongle: ...as also you can clearly see there are two antenna inputs and a special Y cable to connect either inputs to one antenna cable... If that is not your case, please post a (better external) image to convince us that your dongle really have got only one antenna input , only then our responses can be better tailored to your situation... Edited April 13, 2015 by Gioxy Quote
annibal Posted April 14, 2015 Author Posted April 14, 2015 hello thanks for Your Answer come see From Image Only One input of the antenna so if I remove the antenna connected to come do a Receiving channels Identical to the tuner and photos I apologize but as translator wrapped happen not Understand What Vienne explained and more please advise me step by step what do I rate ? thanks Quote
Gioxy Posted April 14, 2015 Posted April 14, 2015 ???? ....the translator you are using is too bad, maybe is better if you write ALSO in italian, as I'm doing now... ???? ....il traduttore che usi è orribile, forse è meglio se scrivi ANCHE in italiano, come sto facendo io ora... Quote
annibal Posted April 14, 2015 Author Posted April 14, 2015 Grazie molto gentile Mi spieghi per favore cosa significa impostare il tuner senza antenna ? Cosicché posso risolvere il problema? Grazie Quote
Gioxy Posted April 14, 2015 Posted April 14, 2015 Please do not write ONLY in italian, you can be banned... First of all, tell us if the tuner is the one of the image and you are using the Y cabke to connect the antenna cable (remember that we can help you as much as you can explain us about your hw/sw set) Then, what Tjod said was to set, one by one, the receivers "State" to from "Normal" to "Do no use" (so that only the other can be used...), then traing to tune some not crypted channels to check if either are working correct. If either are working when are singularly used then we can discuss other aspects. --------- in italian -------------- Per favore non scrivere SOLO in italiano, potresti essere bannato... Prima di tutto dicci se il ricevitore che usi è quello dell'immagine e che utilizzi il cavo a Y per connetterlo al cavo d'antenna (ricorda che possiamo aiutarti solo per quello che tu riesci a spiegarci della tua situazione hw/sw) Quello che Tjod ti diceva era di settare, uno alla volta, lo "Stato" dei ricevitori da "Normale" a "Non utilizzare" (in modo che solo l'altro può essere utilizzato), provando quindi a sintonizzare dei canali non criptati per controllare che entrambi funzionino correttamente. Se funzionano entrambi quando utilizzati singolarmente allora poi possiamo discutere di altri aspetti. Quote
annibal Posted April 15, 2015 Author Posted April 15, 2015 Hello And the same is the tuner Indicated In the picture , and connected with UN connector and Y I anche other UN Question by rate Another tuner connecting to other UN USB port You Make them work together with DVBViewer ? then with 1 tuner record channels and with other premium channels ( encrypted ) ? thanks for your Ciao si il tuner E lo Stesso Indicato Nella foto e collegato con ONU Connettore e Y avrei also ONU altra Domanda da tariffa collegando Un Altro sintonizzatore ad ONU altra porta usb E possibile Farli funzionare Insieme con DVBViewer ? quindi con 1 tuner registrare i canali in chiaro e con l altro i canali premium ( criptati ) ? grazie per le tue Risposte Quote
annibal Posted May 2, 2015 Author Posted May 2, 2015 Hello everyone I thank you for the answers I solved by formatting the PC and reinstalling everything ... driver programs etc. the problem was not the program but some drivers who had installed and was in conflict I thank you for your time and answers Quote
