Fastest -> DVBViewer Pro or GE ?
elia866
Hello guys!
I need to know what version is the fastest one ?
So i have a regular license and i want to know if will ever published a version for Windows x64 and if this could be faster than the current version.
Thanks!
What do you mean by "fastest".
Program start-up time? How often are you starting the DVBViewer every day?
Or playback speed? Do you want to watch a 90 min. film in 10 minus?
Hi Tjod, i mean fastest in zapping (open channel,etc.).
Thanks !
There should be no difference if you using the same settings.
But the TV card and mostly the TV card driver can make a difference.
There is a German Wiki page which settings which can influence the channel switching speed.
(all which will not cause any problems are already set)
http://de.DVBViewer.tv/wiki/Senderwechsel_beschleunigen
  • Like 1
Thank you very much,
very helpful.! :laughing:
However you think an x64 version could still improve in speed zapping?
x64 Version could not improve speed zapping, but zapping with DVBViewer is already very fast if you are using a quick TV card.
  • 1 month later...
Thanks guys,
I am continuing to work in this aspect.
What do you think influenced much more in fast zapping ?
Ram? CPU? Video Card? or other aspects?
Thnaks !
As I said already: TV card/TV card driver are the main factor.
The question is how much time needs the driver to tune a new frequency and forward data to the DVBViewer.
Other factors are how big are the buffer in each component in the playback chain.
Things like Ram and CPU have no real influence. Unless you CPU is most of the time at 100% workload.
