TBS6983 or Cine S2 V6.5 or Skystar 2 Express HD for DVBViewer and KODI
Hello,
I just ordered DVBViewer pro version
And, i'd like to knw wich is the best card for a combination between DVBViewer pro and KODI to show satellite DVB-S2 channels ?
I'm looking for the best choice and stable multimedia center system
Could you help me to choice hardwares and to build this system please ?
Sincerly
Edited by KisSme
Definitely not the Skystar. Technisat has dropped all support for pc cards.
The Cine DD is the best but also the most expensive card.
TBS6983 - there is a prospect
Skystar 2 Express HD - outdated, but works well
Win 8.1 x64 Kodi
thanks !
i'm actualy using a SS2 Ex HD card with KODI and it's a very good card ! :)
for my utilization, i need 2 tuner
so :
2 x SS2 Ex HD = 90€
1 x TBS6983 = 190€
I think, for a normal user, the technisat card is the best solution
I encountered a framerate issue with DVBViewer/KODI/SS2 Ex HD combination
There are constantly micro latency when i look satellite channel
There is no problem when i watch 3D/1080P video fro exemple...
Edited by KisSme
