vramor Posted May 18, 2015 Posted May 18, 2015 Despite of support for TechoTrend CI cards in my DVBViewer, as I setup during installation process I cannot find any information from the CAM (Conax) inserted in TT-budget CT2-4500 CI. Consequentially no one of scrambled DVB-C channels which were found successfuly by TransEdit can be watched. I faced the similar problem when I used TechniSat CableStar Combo HD CI. Then this problem was solved with the AzureWave driver. Unfortunately it doesn't help out with TT. Please help me! Thanks in advance. Quote
Tjod Posted May 18, 2015 Posted May 18, 2015 The card is mostly a DVBSky T980C, so you don't need the TechoTrend files. Post a support.zip Quote
vramor Posted May 19, 2015 Author Posted May 19, 2015 (edited) The same sad story with DVBSky T680C (USB). I can watch FTA channels only, because CAM is unavailable as you can see on this screenshot. support.zip Edited May 19, 2015 by vramor Quote
hackbart Posted May 20, 2015 Posted May 20, 2015 What CAM do you use? You might run Debugview (https://technet.microsoft.com/en-us/library/bb896647.aspx) if you start the DVBViewer. As far as i remember the dvbsky drivers do have debug output in order to find what went wrong. Usually it is either a timing or a general issue with the cam you are using. There is not really much we can do about it, but i have quite a good connection to the manufacturer resp. driver developer from dvbsky. Quote
vramor Posted May 20, 2015 Author Posted May 20, 2015 Thank you very much! There is no problem with CAM detection and interaction when I use DVBViewer with TBS 5880 and the same card I will follow your advice about debugging but I did never use it before. Quote
