Ci slot doesn't seem to work for Terratec H7
ajdulion
Hi DVBViewer team,
I bought this software the other day and I'm very happy with it! There's 1 thing I can't get to work though.
The Ci module in my Terratec H7 doesn't seem to work altough I selected "Has CI module", it did work before in mediaportal perfectly.
FTA channels work perfectly so it's not an issue with the Terratec itself.
Could you please have a look? Tried the search and found something in German I think related to this, but can't read German.
Added the support.zip so you can have a look at all the settings.
Thanks,
Try if the DVBViewer Pro (beta) 5.4 detects the card correctly.
https://www.DVBViewer.tv/members/ > Beta Section
Install the DVBViewer over the current installation.
Options > Hardware delete both devices >> Scan Devices
stop the Recording Service and try if the CI is working.
And post a new support.zip
for using the Recording Service stop the RS and replace the configuration folder\Config\svchardware.xml with this one svchardware.zip
and configure the DVBViewer to work with the RS.
http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer
Thanks for the fast answer!,
The Ci module still doesn't work with the 5.4 beta version even after replacing that file.
The newly generated support.zip has been added.
The svchardware.xml is only for the RS.
Here is a configuration folder\hardware.xml hardware.zip
replace it and test with a stopped RS.
(don't click on "Scan Devices" it will remove the changes made in the xml)
if you use the RS you have to configure the DVBViewer if not you should uninstall the RS.
Replaced hardware.xml in C:\ProgramData\CMUV\DVBViewer, the recording service turned off and restarted DVBViewer but no difference.
I plan to use the recoring service, one of the reasons I bought DVBViewer, which work perfectly for FTA channels so far.
Tjod, maybe the problem is that he doesn't have the Rev.4 of the H7. Rev. 4 has Vendor=32 like in your XML files.
The Rev. 4 has USB\VID_0CCD&PID_10A5, his H7 has USB\VID_0CCD&PID_10A3.
I own the new Rev.4, but unfortunately I don't know the correct Vendor-ID for the old box.
It is Twinhan/AzureWave hardware. According to the support.zip in the first post it has been identified correctly with vendor = 5. Dunno why the CI module won't work...
  • 2 months later...
