McenterFreak Posted June 4, 2015 Posted June 4, 2015 As the topic says, there i no sound when playing hbbTV programs Sound is fine when i play TV programs support.zip Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 Start the DVBViewer via start menu > DVBViewer > Support > DVBViewer Pro (Debug Mode) and open a HbbTV video stop the DVBViewer and generate a new support.zip. HbbTV is working here but depending on the installed codecs an the HbbTV page there can be a problem. Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 OK on you PC the "MainConcept MP4 Demultiplexer" is used. Try installing the LAV Filter again and make sure the LAV Splitter is selected. Enable Options > DirectX > Presets > MP4 (.mov,.mp4,.m4a,Stream) Quote
McenterFreak Posted June 4, 2015 Author Posted June 4, 2015 Same problem, and now DVBViewer sometimes crashes upon exit Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 Start the DVBViewer via start menu > DVBViewer > Support > DVBViewer Pro (Debug Mode) and open a HbbTV video stop the DVBViewer and generate a new support.zip. And about the crashes, the Presets doesn't change anything for live TV. Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 There is only the "MKV subtitles with LAV Filters + VSFilter" Presets enabled.This can only influence the .mkv playback. So nothing has changed at all.Lavstream.fgp is not part of the setup (I thought it was). Put the Lav_mp4_stream.fgp configuration folder\GraphPresets Quote
McenterFreak Posted June 4, 2015 Author Posted June 4, 2015 Sorry, made the wrong selection. Corrected it, but same problem. Copied the .fpg file to configuration\graphpresets folder, but still same problem Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 The question is if "MainConcept MP4 Demultiplexer" or "LAV Spliter" is used for the HbbTV video playback. Check under Settings > Filter or post a new support.zip And delete configuration folder\Cache sometimes cached files can cause problems. Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 Still using "MainConcept MP4 Demultiplexer" Try installing the LAV Filter again and make sure the LAV Splitter is selected. I use currently this version: http://files.1f0.de/lavf/nightly/LAVFilters-0.65.0-11.exe Then run "LAV Splitter Configuration" and make sure mp4 is selected. Quote
McenterFreak Posted June 4, 2015 Author Posted June 4, 2015 Installed 0.65 Checked in LAV Filter that all formats are selected. Still no sound Quote
Tjod Posted June 4, 2015 Posted June 4, 2015 I have tested the HbbTV page you are using here and have no problems. I assume "MainConcept MP4 Demultiplexer" is causing the problem but I don't know why it is still used on you system. Quote
McenterFreak Posted June 4, 2015 Author Posted June 4, 2015 Thanks Tjod I think a reinstall is the way forward Again thanks for Your help Quote
