PiP Border
pankov
Griga,
I'm sorry but can I get answer about
4. Is it possible to disable the borders added in 5.4.0? On my HTPC I don't use a mouse and I use DVBViewer in fullscreen mode only so I don't have any benefit of having these borders - they just ruin the "TV-like" experience
once the size is configured I don't see any point in having the borders especially in fullscreen mode.
Would you consider reverting this ... or at least make the borders optional?
And also, please, check your PMs
Edited by pankov
+1
No.
See my signature below.
Griga,
since you are not willing to revert the change can I kindly ask you to comment on the idea of making the borders optional?
and about this
how can I then ask you in which subforum to start the new English madVR thread so you won't have to move it as you did with the posts above?
You can tell me either via PM or here and I'll delete this question afterwards
thanks Tjod
you can remove both my question and your answer ... or I can do it only for my posts
