Antonio Posted July 31, 2015 Posted July 31, 2015 In the latest release 5.5.0 "Can tune" filter in Channel List not working. For example when pip is active. Quote
Griga Posted July 31, 2015 Posted July 31, 2015 Please give an example that allows to reproduce the issue. I can see no problem here. Usually the "Can Tune" filter only excludes channels if recordings are going on because they have a higher priority than playback. PiP has a lower priority than playback in the main window, so it should never exclude channels from tuning. Quote
Antonio Posted July 31, 2015 Author Posted July 31, 2015 I just updated DVBViewer 5.2.9 => 5.5.0, and I noticed these differences in filtering. In old versions (5.2.9) with PiP this filter excluded channels , now only when recording is going on. Well, it looks like it is so conceived. Quote
Griga Posted August 1, 2015 Posted August 1, 2015 In old versions (5.2.9) with PiP this filter excluded channels That was more or less a bug. However, people got so used to some bugs that they report a bug after it has been fixed. Quote
