zona Posted August 2, 2015 Posted August 2, 2015 I'm using dviviewer for years ( setup with DVMCEBridge, I know that there are newer versions but this one works for me, and WMC7 ) I can't use versions later that version 5.1, this is the last version that I can use, with every new version it crashes after 5-10 min here is the DVBViewer.exe.exception log ######## EXCEPTION: 0xC0000005 at address: 0x072F199A: ACCESS VIOLATION write attempt to address 0x00000000 1: 08/02/15 14:02:09 1: 0 1: Mod: DVMCEBridge, base: 07270000h 1: 1 1: Mod: DVMCEBridge, base: 07270000h 1: 2 1: Mod: DVMCEBridge, base: 07270000h 1: 3 1: Mod: DVMCEBridge, base: 07270000h 1: 4 1: Mod: DVMCEBridge, base: 07270000h 1: 5 1: Mod: DVMCEBridge, base: 07270000h 1: 6 1: Mod: DVMCEBridge, base: 07270000h 1: 7 1: Mod: DVMCEBridge, base: 07270000h 1: 8 1: Mod: DVMCEBridge, base: 07270000h 1: 9 BaseThreadInitThunk +18 bytes 1: Decl: BaseThreadInitThunk 1: Mod: kernel32, base: 77690000h 1: 10 RtlInitializeExceptionChain +99 bytes 1: Decl: RtlInitializeExceptionChain 1: Mod: ntdll, base: 77de0000h 1: 11 RtlInitializeExceptionChain +54 bytes 1: Decl: RtlInitializeExceptionChain 1: Mod: ntdll, base: 77de0000h what is the problem, please fix this issue I have paid for the program several years ago but I'm stuck on version 5.1 and want to use the last version Quote
Tjod Posted August 2, 2015 Posted August 2, 2015 I have paid for the program several years ago but I'm stuck on version 5.1 and want to use the last version. Is your version of DVMCEBridge up tu date. There was never official support for DVBLink from the DVBViewer site. So this mostly should be fixed on the DVBLink site. If there is realy a bug in the DVBViewer (what I don't believe in this case) the DVBLink developers should explain where the problem is (which part of there communication with the DVBViewer didn't work any more) And if you don't like to update to the current DVBLink version. Don't expected it to work with the current DVBViewer Version. Quote
