GinoFamussa Posted August 30, 2015 Posted August 30, 2015 Hi, today there was a feed at 0.8°W about MotoGP. it was Mpeg4 4:2:2 , 4 channels: TopLeft ; TopRight ; BottomLeft and BottomRight. Is there a way to play them as one and watch it correctly? Can You add a tool or plugin in the next updates? Thanks in advance. Gino Quote
nuts Posted August 30, 2015 Posted August 30, 2015 All you need is a suitable Decoder for h.264 4:2:2. Try LAV Filter in software mode. Quote
Tjod Posted August 30, 2015 Posted August 30, 2015 I don't think there will be a solution to play 4 channels in one windows without borders between them inn the foreseeable future. And I don't think many channels will use this technology. Most UHD channels are using HEVC and only one channel. 1 Quote
