elmanoduarte Posted August 30, 2015 Share Posted August 30, 2015 Hi all Many years ago I had a SkyStar 2, working perfectly in my PC. Now it was time to enovate for a SkyStar 2 eXpress HD. Already instaled like all hradware must, and used the incoming CD for the drivers, but, doenst wirk! Tried in windows 7 32 bits, and in win 7 64 bits, and still not geting to work! I m shore the antena is at Hotbird, and it is at perfect condiction. I think its an software problem! Can anyone help me ?? Thanks Quote Link to comment
dvbrewer Posted August 31, 2015 Share Posted August 31, 2015 (edited) Hi all Many years ago I had a SkyStar 2, working perfectly in my PC. Now it was time to enovate for a SkyStar 2 eXpress HD. Already instaled like all hradware must, and used the incoming CD for the drivers, but, doenst wirk! Tried in windows 7 32 bits, and in win 7 64 bits, and still not geting to work! I m shore the antena is at Hotbird, and it is at perfect condiction. I think its an software problem! Can anyone help me ?? Thanks I had the same problem, but I cannot remember exactly the solution . I think there should be two devices in the device manager, one, TechniSat DVB-PC Virtual Network Adapter in "Network Adapters" and the second, TechniSat Skystar 2 eXpress HD in "Sound, video and game controllers" I think when I first installed, the Virtual Network Adapter was not detected, and showed with a yellow exclamation mark in device manager. You need to add driver, point it to SkyNETVirtualNetwork.inf in the Technisat driver folder, it should install. There should be a round tray icon, TechniSat DVB Receiver, with a picture of a satellite, it should show green if a satellite signal is detected (red if not). Restart. In DVBViewer hardware settings Scan Devices. It should show two devices: Skystar 2 eXpress HD and TechniSat BDA Digital Tuner Select "do not use" for Skystar 2 eXpress HD as it is for satellite DSL. Hopefully, then it all should work . Edited August 31, 2015 by dvbrewer Quote Link to comment
elmanoduarte Posted September 1, 2015 Author Share Posted September 1, 2015 Hi, many tanhks for you very good atention Well, it is everything like u described. But just can make it work with the software DvB Dream ! After instal it came working fine. Still not workin with the original DvB software, and so also with Prog DvB, one of my best some years ago It´s to bad for this Board, because in the old PCi version, there was no problem at all configuring it! I going to try in WIndows XP, just for acknowledge Regards, Duarte Quote Link to comment
Tjod Posted September 1, 2015 Share Posted September 1, 2015 Still not workin with the original DvB software,Are you talking about DVBViewer Pro or DVBViewer TE? Quote Link to comment
dvbrewer Posted September 1, 2015 Share Posted September 1, 2015 (edited) Hi, many tanhks for you very good atention Well, it is everything like u described. But just can make it work with the software DvB Dream ! After instal it came working fine. Still not workin with the original DvB software, and so also with Prog DvB, one of my best some years ago It´s to bad for this Board, because in the old PCi version, there was no problem at all configuring it! I going to try in WIndows XP, just for acknowledge Regards, Duarte Did you use the DVBViewer TE that came with the card? It is very outdated, I would recommend buying the latest version, it works fine for me. You do have to make sure to select "do not use" for Skystar 2 eXpress HD in DVBViewer hardware settings, or it will conflict and nothing works. Edited September 1, 2015 by dvbrewer Quote Link to comment
