TBS5980 CI support
wmax
Good morning,
Yesterday I installed a new TBS5980 S2 USB box.
Everything works ok under DVBViewer 5.5.2 except for the CI support.
The CAM menu remains empty and there is no signal of the encrypted channels.
I use a Mediaguard CAM with a Canaldigitaal smartcard (Netherlands sat) and I am sure that these are ok.
Has anybody tested this device? Please help!
Link to comment
Hello Ingbean,
After pasting v1.0.1.2 in the DVBViewer program dir still no succes.
The OSD CAM menu remains blank.
Note: My operating system is Windows10.
Do you have another suggestion?
Wmax
Link to comment
Hello Ingbean,
Problem solved!!!!
The downloaded version of Tbsviewer handeled the encrypted channels properly. So I copied the 3!! Tbsciapi.dll files to the dbviewer program dir and everything worked fine.
I really appreciate your advice.
Best regards,
Wmax
Link to comment
@wmax:
I'm happy to hear that.
No problem, you're welcome.
@Tjod:
I was not sure, if DLL V1.0.1.6 helps this TBS5980-user.
Because V1.0.1.6 was issued from TBS due to my problem with TBS5881.
Please could you inform TBS-team to update their download page http://www.tbsdtv.com/download/ with a newer TBS CI API DLL-version (1.0.1.5 or 1.0.1.6)?
Then other users would have this support benefit too.
Have a nice weekend!
INGBEAN
Link to comment
The newest version should work with all devices.
And I don't have any contact to TBS.
I could only use the contact form there page like any one else.
But I don't have a TBS card. So it is up to a TBS user to ask them to update there website. :innocent:
Link to comment
