iSP Posted September 18, 2015 Posted September 18, 2015 Hi, Just came back from a 2,5 week break the other day and discovered my htpc with DVBViewer backend nog working anymore! As frontend I use kodi and it didn't play back most channels which I thought was odd, so I did a new scan but that didn't really solve it. However it did update some channels so I'm pretty sure the setup works just like before. Well as nothing seemed to solve it I decided to first remove DVBViewer and manually remove all traces of it. Still with a clean setup it won't work and even worse now it won't pickup any channels at all anymore! When looking at the scanning screen it's obvious the signal is being picked up just like before but no (new) channels are being found, this is the exact same custom same ini as used before. So whatever am I doing wrong and/or why can't it pickup any channels anymore? Support.zip: http://s000.tinyupload.com/?file_id=57904748349536922912 Software/Hardware being used; - Windows 10 - DVBViewer 5.5.2 - Recording Service 1.31 - Kodi 15.1 - Digital Devices Duoflex Octopus DVB-C/T with latest drivers (june 2015) Proof of proper reception; Quote
Derrick Posted September 18, 2015 Posted September 18, 2015 Who provided your transponder.ini? Try this ini: ziggo_110315.ini Quote
iSP Posted September 18, 2015 Author Posted September 18, 2015 This .ini makes no difference, I also don't see why it should make any difference. The tuning list I've made myself; on some popular forum I'm the one updating and maintaining way back since 2003'ish. Never had any problems really, same with my logo packs. For your info this is the one I'm using and is more complete than yours (although those extra frequencies don't hold channels currently) [SATTYPE] 1=4000 2=Kabel Ziggo Regio Den Haag [DVB] 0=39 1=474000,3,6875 2=826000,5,6900 3=562000,5,6900 4=786000,5,6900 5=810000,5,6900 6=802000,5,6900 7=490000,5,6900 8=346000,5,6900 9=330000,5,6900 10=338000,5,6900 11=306000,5,6900 12=818000,5,6900 13=354000,5,6900 14=370000,5,6900 15=378000,5,6900 16=522000,5,6900 17=794000,5,6900 18=722000,5,6900 19=130000,5,6900 20=162000,5,6900 21=778000,5,6900 22=314000,5,6900 23=554000,5,6900 24=546000,5,6900 25=466000,5,6900 26=578000,5,6900 27=842000,5,6900 28=386000,5,6900 29=394000,5,6900 30=450000,5,6900 31=458000,5,6900 32=498000,5,6900 33=698000,5,6900 34=586000,5,6900 35=770000,5,6900 36=362000,5,6900 37=170000,5,6900 38=154000,5,6900 39=834000,5,6900 Quote
Tjod Posted September 18, 2015 Posted September 18, 2015 There are no RS configuration files in the support.zip try reinstalling the RS and install the current DVBViewer 5.5.2 and configure the DVBViewer to work with the RS. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer Quote
iSP Posted September 18, 2015 Author Posted September 18, 2015 That's odd, it is configured and just like the wiki. I'll do a complete reinstall tomorrow as it's getting quite late now. Quote
Tjod Posted September 18, 2015 Posted September 18, 2015 At least in the DVBViewer there are no RTSP devices and all the tuner are active. Running the RS Wizard will change this. If you have changed it. You should look at you anti virus software. May by it is responsible for removing the DVBViewer config files. Quote
iSP Posted September 18, 2015 Author Posted September 18, 2015 (edited) Well I tried again as I'm quite certain I did everything as before and as it worked before; http://s000.tinyupload.com/download.php?file_id=00850402800261085344&t=0085040280026108534444862 This htpc has no anti virus software yet, it's a pretty clean install of windows 10 and had no time yet to install it before leaving. On this screenshot you can can see recording service is running and connecting; Everything is working and looking like before but the scanning. Edited September 18, 2015 by iSP Quote
Tjod Posted September 18, 2015 Posted September 18, 2015 The configuration looks now ok apart from the Microsoft MPEG2 Video Codec which doesn't work on Windows 10.So for playback in the DVBViewer you need a different codec like LAV Filters (32 Bit version).And the RS support is not enabled in the DVBViewer. What should be the case after ruing the RS Wizard.http://en.DVBViewer.tv/wiki/Options_Recording_ServiceBut this should not interfere with channel scan.I have currently not a real idea. what causes the problem.Have you checked the antenna cable all of its plug's? Quote
Derrick Posted September 18, 2015 Posted September 18, 2015 For your info this is the one I'm using and is more complete than yours could be, though the screen shot above is showing f=306MHz which isn't an active transponder. And that was the only frequency I could see btw. the channel scan function of the DVBViewer is quite useless. Better try transedit Quote
