caimanonor Posted September 25, 2015 Posted September 25, 2015 hello friends I am trying to configure DVBViewer controller for Android but I could not get it to work , I also installed DVBViewer recording service 1.31 but no dice I need an Android app that works as a remote control 2 Quote
Tjod Posted September 25, 2015 Posted September 25, 2015 Is the DVBViewer correct configure to work with the RS? http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer Post a support.zip Quote
SimonP Posted September 25, 2015 Posted September 25, 2015 There's a lot that could be going wrong so it's hard to know where to start, although you might begin by checking your PC and router firewalls to ensure that the ports it uses are being passed through. All I can tell you at this stage is that it does work, and very well at that. I haven't tried using it to remote control DVBv but being able to browse the guide and schedule recordings is really useful. Quote
caimanonor Posted September 26, 2015 Author Posted September 26, 2015 I tried again , but the result is always negative I installedDVBViewer Recording Service 1 31and configured as a guide pdf Quote
Tjod Posted September 26, 2015 Posted September 26, 2015 I don't know a pdf guide. And I don't see a support.zip to check if the DVBViewer configuration is OK. Quote
bjanuszs46 Posted October 6, 2015 Posted October 6, 2015 What exactly is your problem? I use DVBViewer Controller with no problem, mostly as a remote control (although sometimes I got a strange warning message). Quote
VinoRosso Posted October 8, 2015 Posted October 8, 2015 Disable your windows firewall or configure it correctly Quote
james74 Posted April 2, 2017 Posted April 2, 2017 Streaming not working anymore. Can anyone help me diagnose this fault? I have the Controller app 1.2.0 on a Nexus 7 with Android 6.0.1, working with a RS host 1.33.2.0. I use the app frequently for timer control, less so for streaming. When I tried to stream a live TV channel yesterday, it didn't work. Neither did any recordings. On a first attempt after opening the app, pressing a stream control brings up a blank window with white background; then after 1 second, the screen returns to the Controller GUI. Subsequent attempts produce no visible response. It's possible I had not used streaming since the last update to 1.2.0. I uninstalled the app then installed 1.1.4(build 9) - the last 1.1 build available from github - but this did not work either. Next, I checked authentication wasn't blocking the stream, even though I hadn't changed this or even set a password (I only use this over my LAN). All seemed OK. Other clients were streaming fine. In fact, I can still stream to the tablet using the browser and even to Kodi with the PVR add-on, though the Controller app would be much easier. At the host end, the stream requests produce no effect. This is confirmed by the service log. Further, a packet capture on the LAN interface confirms no stream requests are reaching the host, though I could see other http requests for status, version and "getrecordings". So, what's stopping the app from sending stream requests while allowing other traffic? I removed the MX Player default, but the app doesn't get as far as asking which player to use. Both host PC and tablet have been restarted, but I'm reluctant to cold start the tablet and spend hours reinstalling apps. Does the app have any external dependencies besides the video player? Quote
buttonsNI. Posted August 30, 2017 Posted August 30, 2017 i also can not get the stream to work from any of my android devices. i can however make it work from my windows phone. i test the web browser 111.111.11.11:8089/ios windows phone=yes andriod phone= no (MX player) what am i missing??? many thanks Quote
Tjod Posted August 30, 2017 Posted August 30, 2017 Try HLS streams in the webinterface (ip:8089/ios) an Android. Dos this work? If yes try VLC player as video player on Android or try disabling hardware acceleration in MX player. Quote
buttonsNI. Posted August 31, 2017 Posted August 31, 2017 no this does not work on andriod but i works on windows phone Quote
buttonsNI. Posted August 31, 2017 Posted August 31, 2017 mate sorry for wasting your time but i got it working. the stream con-fig button was hidden . once i realized it was there , i configured the setting and it worked thanks Quote
