Hirsch Posted September 30, 2015 Posted September 30, 2015 Hi I've got DVBViewer running since many years without any trouble with dvb-c or dvb-t even with E-AC3 audio Since i used IPTV, most channels (including crypted ones) work but on few crypted channels i got only the video showing without sound. For Example DVBsource shows : Video State : Enabled / Connected, PID 259 Audio State : No Data / Connected, PID 359 I use DVBViewer pro v 5.5.2.0 with [ removed, violating forum rule §13 ] v 0.6.2.0 , up to date LAV audio decoder (i tried AC3 filter but same result, it seems that it's not a codec issue), on Win7 Thank you for your help
Hirsch Posted October 20, 2015 Author Posted October 20, 2015 Update : with another dvbclient those EAC3 channels work :/ so it's not a driver issue but maybe related with DVBViewer i'm quite fond of DVBViewer so i'd like to keep using it .. Does someone have an idea ?
majstang Posted October 21, 2015 Posted October 21, 2015 yes, maybe you should try AC3filter for the sound and see if that works better.
Cris7 Posted October 31, 2015 Posted October 31, 2015 (edited) Hi there, I have the same issue. Since an update from the IPTV provider I think there is an issue or a messed up between 6 ch AC3 and EAC3 format. DVBViewer seems to not be able to make difference between those codecs anymore. Or why is DVB showing: "Audio State : No Data / Connected" I don't get it. As my friend says, Progdvb is able to handle those channels very well. AC3filter was tested and as he said it's not a mater of codec but a decoding mater. A clue maybe, something is messed up during the export file from transedit to the .ini file for DVBViewer? It's a very annoying situation for a member of DVBViewer. It's been several month now the problem is actualy here. Everything was tested to make this work on PC with a simple 2 ch out. Need help! cheers, thx in advance. ps: sorry, english is not my native language. Edited October 31, 2015 by Cris7
Cris7 Posted October 31, 2015 Posted October 31, 2015 (edited) Absolutely, and decrypted using a plugin for reading the card. why that? Edited October 31, 2015 by Cris7
Griga Posted October 31, 2015 Posted October 31, 2015 Because most likely the audio stream is not decrypted if the DVBViewer Filter reports "no data". There was a similar issue with TBS DVB devices lately because the driver did not recognize the E-AC3 stream type as audio that must be decrypted by the CI/CAM. Please note that DVBViewer does not support IPTV decryption (so it can't do anything wrong in this respect) and that discussions about software decrypting are not allowed in this forum (see §13 of the forum rules): Do not ask for or discuss plugins for descrambling/decrypting pay-tv or key-codes.Although the DVBViewer Pro provides full pay-tv functionality it must only be used in combination with a valid subscription of a pay-tv provider, a tv-card/box featuring a "conditional access module" (CAM) and/or the corresponding "common interface" (CI) with a smart-card. This applies regardless whether software-descrambling is allowed in your country or not. So you need to contact the plugin author or to find some other forum where you can ask for help. Or simply use ProgDVB. Sorry, no better news. Topic closed.
