jim curver Posted October 8, 2015 Share Posted October 8, 2015 Hello, Today I installed a new DVBSKY T680C with IC USB box.Everything works ok under DVBViewer 5.5.2 except for the CI support.The CAM menu remains empty and there is no signal of the encrypted channels.With DVBSKY player(DVBViewer light édition) all works fine.When i shut down it and open directly DVBViewer on the same channel (last in DVBSKY player),this channel is décrypted but no other one after changing it.No api.dll in DVBSKY program files directory.Does anyone have a solution? Quote Link to comment
INGBEAN Posted October 14, 2015 Share Posted October 14, 2015 (edited) Hello jim curver! Please post a "Support.zip". Which USB-driver version did you install? Which OS do you use? Working DVBSky-Player version? I have a DVBSky T680C running on DVBViewer V5.5.0 (Windows 7 SP1, 64-bit & Windows XP Home SP3, 32-bit) without problems. Did you previously install drivers of a different TV-USB-box? INGBEAN Edited October 14, 2015 by INGBEAN Quote Link to comment
