start a vbs script on DVBViewer closes
robob
i'm using the internal Script windowload.vbs, to run some programs when I open DVBViewer.
is-it possible to create a event script when DVBViewer cloes ? (a windowclose.vbs script)
how to do that ?
thank you.
If you stop DVBViewer by key or remote you can implement a handler for this command in command.vbs.
I saw a lot of stuff in the forum with command.vbs but, noob question, where is this command.vbs ? I can't find it in DVBViewer folders. :ermm:
I'm on DVBViewer pro 5.5.2.0.
I write a command.vbs
Sub Main (ActionID)
Select Case ActionID
Case 7
OSD.ExecNewProcess "C:\WINDOWS\notepad.exe", "", False, True
End Select
End Sub
I write a command.vbs in C:\Program Files\DVBViewer\Scripts
Sub Main (ActionID)
Case 7
End Select
End Sub
Id 7 is channel list, but nothing apen when I open the channel list.
"disable the internal scripting engine " is unticked
May be I forgot something ?
Anyway to run a script on close event (by keyboard, remote or end recording) ?
You have to redefine the command with an ID > 20480. Only for this commands the Command.vbs is executed.
Here are some examples (unfortunately in German): http://de.DVBViewer.tv/wiki/Command.vbs
Don't know if an english Wiki page exists.
How to redefine input command (in english): http://en.DVBViewer.tv/wiki/Options_Input
