jirim100 Posted December 15, 2015 Posted December 15, 2015 Good day, is Terratec T5 rev2 tuner handled absolutly correctly? Occassionally when start recording then in first minute are not data and data only are after the first restart of recording. For example today 15.12 when start recording with name "lkjkjkjkj". See log file. support.zip
Tjod Posted December 15, 2015 Posted December 15, 2015 Run the RS Wizard in the DVBViewer. To give the RS control over the hardware. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer only one program should try to access DVB hardware directly. And you should enable "Auto split on channel data changes". But if the problem is simply a slow initialisation of the CAM I have no real idea.
jirim100 Posted December 15, 2015 Author Posted December 15, 2015 (edited) Run the RS Wizard in the DVBViewer. To give the RS control over the hardware. http://en.DVBViewer.tv/wiki/Recording_Service_Installation_Guide#Setting_up_DVBViewer only one program should try to access DVB hardware directly. But only Recording service accessing all hardware. And you should enable "Auto split on channel data changes". Why? How is related to this problem? And I don't want split recording when channel data changes. But if the problem is simply a slow initialisation of the CAM I have no real idea. But this is pure DVB-T tuner (it's dual tuner with diversity mode). Edited December 15, 2015 by jirim100
Tjod Posted December 15, 2015 Posted December 15, 2015 But only Recording service accessing all hardware.If you don't use the DVBViewer at all. And I don't want split recording when channel data changes.The Recording will only be spit in situation where the recording otherwise would stop. But this is pure DVB-T tuner (it's dual tuner with diversity mode).The lkjkjkjkj recording was on "DVB-C Tuner (6)" with CAM involved and not on DVB-T. And if you are using diversity mode. You have to disable one tuner of the card in the RS. Diversity mode needs two tuner for one recording. But the RS has no information about this. And if the RS uses the secend tuner e.g. for the EPG update is will stop the diversity mode.
jirim100 Posted December 15, 2015 Author Posted December 15, 2015 The lkjkjkjkj recording was on "DVB-C Tuner (6)" with CAM involved and not on DVB-T. You have the problem with reading yours logs? In svcdebug.log: 15.12.15 08:52:49.943 TRecording ($028EB150) W:\For The Record\lkjkjkjkj; nahráno 2015-12-15.ts Discontinuities: 0 - Total size: 0,00 KB - Device:TERRATEC T5 Rev.2 Tuner 2 (8) ... 15.12.15 09:09:50.035 TRecording ($028EB150) W:\For The Record\lkjkjkjkj; nahráno 2015-12-15.ts Discontinuities: 0 - Total size: 516,42 MB - Device:TERRATEC T5 Rev.2 Tuner 2 (8) In svcrec.log: 15.12.15 08:52:49.943 W:\For The Record\lkjkjkjkj; nahráno 2015-12-15.ts Discontinuities: 0 - Total size: 0,00 KB - Device:TERRATEC T5 Rev.2 Tuner 2 (8) 15.12.15 09:09:50.035 W:\For The Record\lkjkjkjkj; nahráno 2015-12-15.ts Discontinuities: 0 - Total size: 516,42 MB - Device:TERRATEC T5 Rev.2 Tuner 2 (8) This is NOT "DVB-C Tuner (6)" but "TERRATEC T5 Rev.2 Tuner 2 (8)" ! And if you are using diversity mode. You have to disable one tuner of the card in the RS. Diversity mode needs two tuner for one recording. But the RS has no information about this. And if the RS uses the secend tuner e.g. for the EPG update is will stop the diversity mode. Yes, I know about it. Therefore my preference of tuners is the following and I newer record concurrently from 4 or more mux: Terrestrial TERRATEC T5 Rev.2 Tuner 2 (8) Normální Terrestrial PCTV 291e/461e BDA 28179 TVTuner (9) Normální Terrestrial AF9015 BDA Filter 3 (1) Normální Terrestrial AF9015 BDA Filter 5 (3) Normální Terrestrial TERRATEC T5 Rev.2 Tuner 1 (7) Normální Terrestrial AF9015 BDA Filter 4 (2) Normální Terrestrial AF9015 BDA Filter 6 (4) Normální Terrestrial USB 2.0 BDA DVB-T Tuner (5) Nepoužívat Cable USB 2.0 BDA DVB-C Tuner (6) Normální Cable PCTV 291e/461e BDA 28179 TVTuner C (10) Nepoužívat But whether have this tuner diversity is not here relevant. I simply start recording and in first 60 seconds was not data and recording had to be restarted - after it recording was ok. This occassionally happen and I think you maybe don't correctly handle this tuner (?). In changes of RS 1.32 you wrote: Fix: Hardware: The TerraTec Connect N3 network tuner was not handled correctly. My tuner is too TerraTec, maybe a similar problem?
