hoto44
Hello,
here is my newest OSD-SKIN: Contrast.
Please note:
Contrast contains MR.SkinHelper functionality (BluFuzz - thanks to SnoopyDog). So you need the MR.SkinHelper plugin to be installed: http://www.DVBViewer.tv/forum/topic/38952-osd-skin-blufuzz-mit-optionaler-scrobbler-funktion/
For Contrast you need the font Sony_Sketch_EF and Aeon Main (both included in fonts folder of the skin) installed on your system.
Installation:
basically like any other skin :
The png/jpg-files (images) from images 1 and images 2 folders in the attachments uploaded are to be copied back in the images folder of the OSD-skin folder so that the skin contains only one images folder.
In addition following plugins are required: X-skin-plugin and concinnity-plug-in.
Also you need miniepgvars-plugin. It shows the sattelite frequenz and strength in mini-epg.
Additionaly MyMovies, MySeries, TV Man, neutrinocl, and online are also supported by Contrast.
Home images are personal flavour and can be changed of course.
Kind regards
hoto44
Contrast.zip
images1.zip
images2.zip
Edited by hoto44
  • Like 3
...alternative background for this OSD skin.
Simply replace the black background file (background_xxx.png)
with the same name in the images folder of the skin.
Kind regards
hoto44
Edited by hoto44
