nidzesi Posted January 4, 2016 Share Posted January 4, 2016 Hi, I just bought a new tv and I wanted to watch some channels LIVE on tv from my pc (smart tv is connected to same router as computer, so I guess it's possible). I installed DVBViewer Recording Service and configured it, also checked UPNP... When I start web interface I get no option to choose any channel and see it's epg (http://i.imgur.com/UDSIxQv.png) and when I choose UPNP Media I get no TV channels (http://i.imgur.com/D25y8z0.png). Same on tv. Any help? What am I doing wrong? Thank you in advance. Link to comment
Derrick Posted January 4, 2016 Share Posted January 4, 2016 If UPnP is activated you should see the DVBViewer Media Server on your smart tv. If not check network configuration and firewall settings. Link to comment
nidzesi Posted January 4, 2016 Author Share Posted January 4, 2016 DVBViewer Media Server is visible on my tv... But when I get in there and select TV, then ALL Channels list is empty... Cann't select anything... I just want to see the channel which is played on DVBViewer at the same time on tv, is that possible? Link to comment
Valdinei Posted January 9, 2016 Share Posted January 9, 2016 Getting the topic nidzes! Hello everyone! I'm learning to use DVBViewer now and I'm going through a problem. DVBViewer + kodi, kodi does not receive the HD channels, sd ok await help! Hug! Link to comment
