Freezes until DVBViewer loaded
boborg
I installed a Skystar2 in a friends PC. Funny thing is that until DVBViewer is loaded the system (WinXP Pro) suffers from short freezes.
Anyone seen that problem before?
This could have several problems.
I had such a problem because the LNB was damaged. Next thing could be damaged card, IRQ problem bad driver installation, directX problems.....
But without informations ( When it freeze, see loading window and all other informations see at http://www.DVBViewer.com/forum/index.php?s...?showtopic=2210 ) we can't help you.
Does the TechniSat application run? Maybe it is trying to do something. Try to close it as it is not needed by DVBViewer.
until DVBViewer is loaded the system suffers from short freezes.
This might be a problem with the driver release 4.2.11; if you isntall the 4.2.10 or the 4.3.0, the problem will not occur. After you removed the device in device manager, you should remove the file C:\Windows\System32\Drivers\skynet.sys. You also have to use the applications for the used drivers.
kaiser.wilhelm2
