transco Posted December 18, 2004 Share Posted December 18, 2004 I'm using the B2C2 ATSC-T card with DVBViewer V2.3beta. Card works OK with B2C2's TV4PC, TSReader, etc. Unfortunately I am not able to do a channel scan with DVBViewer. The "Scan" button remains grayed out (inactive). Any ideas? Quote Link to comment
Guest hackbart Posted December 18, 2004 Share Posted December 18, 2004 Hi, hmm normally this should work fine (i tested it virtually in montery bay area). If you select the america region inside the scanner and push the scan button it should work fine. Christian PS: The scan button only appears grey, if there is no name given inside the "root" entry america.ini Quote Link to comment
Guest hackbart Posted December 18, 2004 Share Posted December 18, 2004 shame on me, i'm really stupid i forgot to add the file inside the beta. Just copy the file and put it into the transponders directory and everything should work fine with the scanner.. Christian Quote Link to comment
