M3U files not playing
championc
I read in the release notes that m3u files were to be supported from ver 5.6.0 but I have a file which works with VLC Player but won't play on ver 5.6.1
Any thoughts ?
Only "DVB IPTV lists" (multicast stream with one IP:port combination per channel) are supported as transponder list for a DVB IPTV channel scan.
Nerveless it is possible to open m3u files as play-list in the DVBViewer Pro. And if the filter codecs an splinter are installed im Windows playback should work. But you can't add them to the channel list.
I simply got my m3u file, right clicked on it, and selected Open with DVBViewer. So I wasn't trying to add it to any lists - only to just start playing the channel. Since it works OK with VLC Player, I can only assume that I have the correct codecs in place.
So how can I use it ?
VLC uses its on Codecs and doesn't rely on the DirectShow filters installed in the system.
A good starting point is LAV Filters (the DVBViewer needs the 32 Bit version of codecs).
But then it depends on the streaming protocol and the codecs used by the stream.
Many thanks. I've tried LAV Filters but unfortunately no joy. I've sent you a PM with a link to mu M3U file and I'd be very grateful if you could check it and try it out :(
I have currently no idea what the problem there is.
Is there any debugging info that I can do and provide to the developers to help resolve the issue or to prove that there is indeed a bug ?
You could start DVBViewer via "DVBViewer Pro (Debug Mode)" then you get more informations in the DVBViewer.log (streaming URL maybe error nemeses which codecs are used). But I don't know if there are helpful informations.
That mostly relies on the DirectShow System.
https://msdn.microsoft.com/en-us/library/windows/desktop/dd375470(v=vs.85).aspx
You could try opening the stream in GraphStudioNext and then try to get the DVBViewer to use the same Filter via GraphPresets
Now I'm completely lost !!!
Where is the Debug Mode in DVBViewer Pro ? I even searched in the wiki and couldn't find it.
As for GraphStudioNext, I've absolutely no idea as to what to do in it. I looked at images in Google and it shows various components linked together. I assume that you build these things up. I also assume that no video will be displayed at all, and that it's just a tool.
Edited by championc
Windows start menu > all programs > DVBViewer > Support > DVBViewer Pro (Debug Mode)
Mixed Results - using the latest ver 5.6.2
I got BBC to work (First and Last attempt) but others wouldn't open when using the same method which is strange. The middle two open fine with VLC Player
10.04.16 19:03:38.425 OSD Startup Init Complete
10.04.16 19:03:38.452 TfrmLoader Status Completing Initialization...
10.04.16 19:03:38.472 TfrmLoader Status
10.04.16 19:04:01.674 TfrmMain LoadFile http://192.168.1.2:8001/1:0:1:189D:7FD:2:11A0000:0:0:0::BBC One Lon
10.04.16 19:04:01.675 TfrmMain LoadFile try TStreamingRenderer
10.04.16 19:04:02.868 ConnectAudio ACodec: Microsoft DTV-DVD Audio Decoder
10.04.16 19:04:02.870 ACodec Microsoft DTV-DVD Audio Decoder
10.04.16 19:04:02.917 ConnectVideo VCodec: Microsoft DTV-DVD Video Decoder
10.04.16 19:04:03.046 AddVideoRenderer EVR added
10.04.16 19:04:03.147 EVR VideoProcessorMode {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F} 00000000
10.04.16 19:04:03.147 Used Filter: EVR Renderer (Custom)
10.04.16 19:04:03.147 Used Filter: Microsoft DTV-DVD Video Decoder
10.04.16 19:04:03.147 Used Filter: Default DirectSound Device (Audio A)
10.04.16 19:04:03.147 Used Filter: LAV Video Decoder
10.04.16 19:04:03.147 Used Filter: Audio Callback (Standard)
10.04.16 19:04:03.147 Used Filter: Microsoft DTV-DVD Audio Decoder (Audio A)
10.04.16 19:04:03.147 Used Filter: MPEG-2 Demultiplexer (Standard)
10.04.16 19:04:03.147 Used Filter: http://192.168.1.2:8001/1:0:1:189D:7FD:2:11A0000:0:0:0::BBC One Lon (Standard)
10.04.16 19:04:03.147 TStreamingRenderer SetTargetHandle 0002048C
10.04.16 19:04:03.147 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:04:03.236 TStreamingRenderer RealignWindow (VP) (0,0,445,334)
10.04.16 19:04:03.241 TStreamingRenderer RealignWindow (VP) (0,0,445,334)
10.04.16 19:04:04.144 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:04:04.149 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:05:22.304 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:05:22.756 TfrmMain End App before OSD terminate
10.04.16 19:05:22.797 End App -----------------------------------
10.04.16 19:05:29.716 OSD Startup Init Complete
10.04.16 19:05:29.741 TfrmLoader Status Completing Initialization...
10.04.16 19:05:29.761 TfrmLoader Status
10.04.16 19:05:38.711 TfrmMain LoadFile http://192.168.1.2:8001/1:0:1:AF4:7ED:2:11A0000:0:0:0:
10.04.16 19:05:38.711 TfrmMain LoadFile try TStreamingRenderer
10.04.16 19:05:39.915 ConnectAudio ACodec: Microsoft DTV-DVD Audio Decoder
10.04.16 19:05:39.917 ACodec Microsoft DTV-DVD Audio Decoder
10.04.16 19:05:39.964 ConnectVideo VCodec:
10.04.16 19:05:40.086 AddVideoRenderer EVR added
10.04.16 19:05:40.111 EVR VideoProcessorMode {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F} 00000000
10.04.16 19:05:40.112 Used Filter: EVR Renderer (Custom)
10.04.16 19:05:40.112 Used Filter: Default DirectSound Device (Audio A)
10.04.16 19:05:40.112 Used Filter: LAV Video Decoder
10.04.16 19:05:40.112 Used Filter: Audio Callback (Standard)
10.04.16 19:05:40.112 Used Filter: Microsoft DTV-DVD Audio Decoder (Audio A)
10.04.16 19:05:40.112 Used Filter: MPEG-2 Demultiplexer (Standard)
10.04.16 19:05:40.112 Used Filter: http://192.168.1.2:8001/1:0:1:AF4:7ED:2:11A0000:0:0:0: (Standard)
10.04.16 19:05:40.112 TStreamingRenderer SetTargetHandle 0003045E
10.04.16 19:05:40.112 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:05:40.415 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:05:55.498 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:05:56.444 TfrmMain End App before OSD terminate
10.04.16 19:06:02.451 OSD Startup Init Complete
10.04.16 19:06:02.476 TfrmLoader Status Completing Initialization...
10.04.16 19:06:02.495 TfrmLoader Status
10.04.16 19:06:09.271 TfrmMain LoadFile http://192.168.1.2:8001/1:0:1:1076:7E5:2:11A0000:0:0:0::Sky Sports 1
10.04.16 19:06:09.271 TfrmMain LoadFile try TStreamingRenderer
10.04.16 19:06:10.540 TStreamingRenderer SetTargetHandle 00080438
10.04.16 19:06:37.921 TfrmMain End App before OSD terminate
10.04.16 19:06:44.397 OSD Startup Init Complete
10.04.16 19:06:44.424 TfrmLoader Status Completing Initialization...
10.04.16 19:06:44.443 TfrmLoader Status
10.04.16 19:06:50.657 TfrmMain LoadFile http://192.168.1.2:8001/1:0:1:189D:7FD:2:11A0000:0:0:0::BBC One Lon
10.04.16 19:06:50.657 TfrmMain LoadFile try TStreamingRenderer
10.04.16 19:06:51.870 ConnectAudio ACodec: Microsoft DTV-DVD Audio Decoder
10.04.16 19:06:51.872 ACodec Microsoft DTV-DVD Audio Decoder
10.04.16 19:06:51.919 ConnectVideo VCodec: Microsoft DTV-DVD Video Decoder
10.04.16 19:06:52.050 AddVideoRenderer EVR added
10.04.16 19:06:52.134 EVR VideoProcessorMode {BF752EF6-8CC4-457A-BE1B-08BD1CAEEE9F} 00000000
10.04.16 19:06:52.134 Used Filter: EVR Renderer (Custom)
10.04.16 19:06:52.134 Used Filter: Microsoft DTV-DVD Video Decoder
10.04.16 19:06:52.134 Used Filter: Default DirectSound Device (Audio A)
10.04.16 19:06:52.134 Used Filter: LAV Video Decoder
10.04.16 19:06:52.134 Used Filter: Audio Callback (Standard)
10.04.16 19:06:52.134 Used Filter: Microsoft DTV-DVD Audio Decoder (Audio A)
10.04.16 19:06:52.134 Used Filter: MPEG-2 Demultiplexer (Standard)
10.04.16 19:06:52.134 Used Filter: http://192.168.1.2:8001/1:0:1:189D:7FD:2:11A0000:0:0:0::BBC One Lon (Standard)
10.04.16 19:06:52.134 TStreamingRenderer SetTargetHandle 00100268
10.04.16 19:06:52.134 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:06:52.402 TStreamingRenderer RealignWindow (VP) (0,0,445,334)
10.04.16 19:06:52.409 TStreamingRenderer RealignWindow (VP) (0,0,445,334)
10.04.16 19:06:54.133 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:06:54.138 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:07:00.476 TStreamingRenderer RealignWindow (VP) (0,0,594,334)
10.04.16 19:07:00.872 TfrmMain End App before OSD terminate
10.04.16 19:07:00.913 End App -----------------------------------
Edited by championc
