stryker Posted December 19, 2004 Posted December 19, 2004 Hi guys. Actually am facing a problem with my sky star 2 . i did uninstall to the drivers and honestly i had a bad uninstall . so when i tried to reinstall it i got this msg " RegDBGetKeyValueEx " And it sometimes say that it have to uninstall the old drivers which i uninstalled it but i dont know why it keeps doin this then bords the install . ps. my drive name was F: , i changed it to D: is this might be the problem ? plz waiting for ur help urs Moh Quote
Klausing Posted December 19, 2004 Posted December 19, 2004 If you change your drivename from F to D you have to change all hundreds of Settings of programms and inside the registry ! In your case you havn't done this. So, the programms like the uninstall routine can't work fine and this give you this problems. Quote
stryker Posted December 19, 2004 Author Posted December 19, 2004 Thanks for ur update Well , this is new drive that i changed the name of it . it only has couple of programs and one of these programs is the dvb . Iam having no problem uninstalling and reinstalling the other softwares . Please if u can lead me to the solution . Thanks again urs Moh Quote
