Playback upside down for .MOV and .MP4
Langhuse
We use DVBViewer for playback of movies from our phones.
I discoverede that the movie (.MOV and .MP4) is sometimes shown UPSIDE/DOWN.
  • Playback is correct on Android/IOS
  • The movie thumnail in WIN10 is correct.
  • Playback using VLC is correct.
A simple test found that it depended on the phone orientation, when recording
E.g.
- playback is OK if start button is on the right for Android 6.x
- playback is upside/down if the phone is rotated 180 degrees.
I made the same test with an Iphone - same result :wassat: :wassat: :wassat:
Equipment:
- Samsung S7, Android 6.x
- Iphone 6S, IOS latest
Probable cause:
- DVBViewer does not check the "orientation" included within the movie-file.
I did try to attatch 2 very small examples, but your uploader would not allow 1M file to upload.
Which codecs are used for playback?
Settings > Filter > ...
mostly this is a problem inside the video codec settings.
