evald80 Posted December 19, 2004 Posted December 19, 2004 It will be possibile making copy paste of a selected channel from a directory to another ?? Quote
Hartwig Posted December 19, 2004 Posted December 19, 2004 At the moment you can use drag&drop as a little workaround Quote
NameIt Posted December 19, 2004 Posted December 19, 2004 Sometimes i wished such a functionality too. Drag'nDrop is a nice workaround for CUT'nPaste but if you wish to generate a new Category/Folder you can use only an old folder, rename that folder and move him to the right position. Quote
Griga Posted December 19, 2004 Posted December 19, 2004 but if you wish to generate a new Category/Folder you can use only an old folder, rename that folder and move him to the right position. ...which is not true. Select a channel that shall be a member of the new category, go to the Edit Tab, enter the desired category name, click "Add" or "Update", and the category will be created, if it doesn't exist yet. Quote
NameIt Posted December 20, 2004 Posted December 20, 2004 ah, nice to know. thank you very much, griga. Wer liest schon das _komplette_ Handbuch ;-) NameIt Quote
