how can enable OSD in DVBViewer 5.0.0.0
aramrahgozar
Hi
how can i enble osd in ver 5.0.0.0 ?
Thanks
The current DVBViewer version is 5.6.2 why using a out dated version?
And the OSD is enabled by default an a fix part of the DVBViewer. You can only change the OSD-Skin.
Just press OSD-OK [return] or OSD-Menu [Esc] to open OSD pages.
If you have problem with the OSD in the current DVBViewer post a support.zip
  • Like 1
