quack Posted July 2, 2016 Posted July 2, 2016 Hi there, I don't know why but recordinds made through Recording Service cannot be opened in VLC (but they play well in DVBViewer). If I record directly from DVBViewer (not using Recording Service), the files can be played by VLC. Here is an example of a VLC-non-working recording : http://www.megafileupload.com/bguF/2016-07-02_19-53-13_TF1_HD+_(fra)_.ts Can you help me ? Many thanks
Griga Posted July 2, 2016 Posted July 2, 2016 Here is an example of a VLC-non-working recording VLC plays it here quite happily However, there is a known VLC bug. It can't cope with the EPG Information files (*.txt) created by the RS. It tries to read them as subtitle file and fails badly.
quack Posted July 2, 2016 Author Posted July 2, 2016 You're absolutely right, VLC messes up with the EPG information file. Once I rename it, it's good to go. Thank you for your help
Tjod Posted July 2, 2016 Posted July 2, 2016 Or change the setting in VLC Player (disable subtitle auto detection) http://www.DVBViewer.tv/forum/topic/39368-file-format-for-recording-service/
