can't play pva files
clausss2
I have a skystar2 card with newest drivers & DVBViewer TE
When I record in pva format I cannot playback recorderd files within DVBViewer. The error message i get is: Kann Video nicht rendern error: 0x80040265
Is this generally impossible ?
Working with the recorded files in pvacut is fine and I can produce working DVDs ;-)
(Using Prgdvb doesn't work well either. Here I can't view the self recorded pva's too)
What could be the reason for the error ?
Thanks Claus
No. You need to install a PVA Demultiplexer DirectShow filter. The only one I know is included in the Elecard Decoder Package (Download).
However, seeking / changing the playback position is not supported by the PVA Demultiplexer.
Please read more about the Elecard Package here.
So is it right that the recording option pva isn't for internal playback
The mpg(PS) and the m2v/mp2 splitted files can be played back ...
Thanks Claus
No, like most other media players the DVBViewer is based on DirectShow. That means you need to install a demultiplexing filter capable of playing back PVA. You shouldn't use PVA, though, since it has only disadvantages.
Bye, Oliver
Uuups .. the only reason to use pva was producing dvd's
DVBViewer(PVA) -> pvacut(cut->pva) -> pvastrumento (demux->mpv+mpa) -> ifoedit(-> vob) -> imgtool(burn dvd)
Thx Claus
@clauss2: If you want to purchase the DVBViewer Pro and if you don't know how to do it, please read this German description.
@Everybody: I will not provide any support via PM!!!
??? Why? Latest version is working OK :bye:
Really? Latest Elecard PVA Demuxer? I didn't know that they are still working on it... good news.
seeking / changing the playback position ist possible with "mediaplayer classics", too.
Really.. but "mpeg2dmx.ax" from Elecard:)
