Nayef Posted July 12, 2016 Posted July 12, 2016 (edited) Hi i have multi tuner (6) input . Each input has a separate Diseqc (4 port) as this map: DVB-S2 A & Diseqc (1+2+3+0) (13E+ 16.0E + 26E + blank) DVB-S2 B & Diseqc (1+2+3+0) (13E+ 16.0E + 26E + blank) DVB-S2 C & Diseqc (1+2+3+0) (13E+ 16.0E + 26E + blank) DVB-S2 D & Diseqc (1+0+0+4) (16E+ blank + blank + 13E) DVB-S2 E & Diseqc (1+0+0+0) (13E + blank +blank +blank) DVB-S2 F & Diseqc (1+0+0+0) (13E + blank +blank +blank) When searching for channels for "DVB-S2 D" and change setting Diseqc to set (1 input & 4 input) , the channels do not work on other DVB-S2 (A+B+C+E+F) Because the installation of different Diseqc . and must resetting for other again and "DVB-S2 D" not work channel ! i try group channel for Each input but that not help me any way to save setting Diseqc for Each DVB-S2 and No problems with the rest of the other channels support.zip Edited July 12, 2016 by Nayef Quote
Griga Posted July 13, 2016 Posted July 13, 2016 Sorry, DVBViewer can't handle such an inhomogeneous DiSEqC setup. It would require a per-device DiSEqC mapping mechanism. If you can't change your DiSEqC hardware so that it provides the satellite positions consistently there is no reasonable way to use device D - at least not in a single DVBViewer instance with a single channel list. However, you may use it in a second DVBViewer instance (e.g. after installing DVBViewer GE, which is the easiest way) for special purpose. In such a setup the first instance (your existing installation) must never use device D and the second instance only device D. Quote
Nayef Posted July 13, 2016 Author Posted July 13, 2016 (edited) But I did not have this problem in previous versions after scan for each input all channel working fine in DVBViewer pro ... but after update : NO I do not remember any version? But I think that before the new channel management and scan . Edited July 13, 2016 by Nayef Quote
