kroegtijger Posted July 13, 2016 Posted July 13, 2016 Is it possible (or can it be made possible) to get TransEdit to start to analyze (or start analyzing a file) from the commandline and return an XML-output-file? Or can this only be done from the GUI? Quote
Griga Posted July 13, 2016 Posted July 13, 2016 Is it possible o get TransEdit to start to analyze from the commandline Yes. Simply pass a TS file or URL as commandline parameter. and return an XML-output-file? No. UI only. Quote
kroegtijger Posted July 13, 2016 Author Posted July 13, 2016 Yes. Simply pass a TS file or URL as commandline parameter. No. UI only. Is there any possibility that an export will become possible in the (near) future? This would make it a whole lot easier to get this scripted. Thanks Quote
userip Posted July 18, 2016 Posted July 18, 2016 Hi, This can be done in this way: - Execute TransEdit with command line for reading from your source with the parameter to streaming the TS to a remote IP:PORT. - Execute the free "dvbsnoop" for listening in the IP:PORT (dvbsnoop.sourceforge.net) The only problem is: At time, TransEdit don't have an option for streaming the TS to a remote address. I request this in this thread: http://www.DVBViewer.tv/forum/topic/56627-streaming-button-in-transedit/ And as I commented, this is only a some minutes of coding effort. However, the developers think that this funtionality is useless. I hope they change their mind! Quote
