DVB-C/T/T2 Real Blind Scan
Derrick
DVBViewer/TransEdit provide a "blind scan" mode for scanning different frequency ranges. Due to the restriction of BDA this is only a pseudo blind scan. For DVB-S(2) you can perform real bind scan with CrazyScan if it is supported by the hardware.
Now the same is possible for T/T2/C/C2 with CrazyScan2. I've got an Edision Optimuss DVB-C/T(2) stick which seems to be identical with DVBSKy T330. After installing the DVBSKy driver CrazyScan2 identifies the stick as supported hardware. With the latest crazyscan2 AirScan is possible which is the equivalent to blind scan in normal crazyscan. Here a couple of screen shots:
DVB-C
DVB-T(2)
T2 constellation
PLP1 stream
Links:
https://sourceforge.net/p/crazyscan/blog/
http://radioforum.foren.mysnip.de/read.php?8773,1344801
  • Like 2
